KietNgo
Thinking about buying a raspberry pi...is it for me?
Fri Apr 11, 2014 3:50 am
Right now I have two hard drives connected to my router.
I'm currently using a WDTV to stream media from the routers hard drives to my TV.
Would this do the same? Would be 720P to 1080P MKV videos.
4thdwarflord
Re: Thinking about buying a raspberry pi...is it for me?
Mon Apr 14, 2014 7:36 pm
My main concern would be the network rate - 150mbps or so probably isn't enough for much when it comes to video. If your current setup works, I see little reason to change it.
Jessie
Mon Apr 14, 2014 8:01 pm
You want to serve from the RPi or run it as a XBMC client?
4thdwarflord wrote:My main concern would be the network rate - 150mbps or so probably isn't enough for much when it comes to video. If your current setup works, I see little reason to change it.
Where does this 150 mb/sec figure come from? Also assuming that is a reliable figure its still 18.75 MB/sec.
EDIT: I guess you are referring to a USB HDD sharing bandwidth of the USB ethernet adapter. In which case I agree it wouldn't make a good server for 1080p content.
