Fastest booting OS
What is the fastest booting Linux OS for the Pi?
Re: Fastest booting OS
I don't think you'll find the fastest Linux OS they all have to do that usually init stuff on boot.
Raspbian is probably the best distro to use for software support and updates although RiscOS (not Linux OS) is quite a fast booter to the desktop.
Richard S.
Richard S.
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Why is it important?Pingpong1109 wrote:What is the fastest booting Linux OS for the Pi?
Even the fully bloated Raspbian comes up before you can say "Raspbian runs".
I am just wondering what is the fastest booting OS.DougieLawson wrote:Why is it important?Pingpong1109 wrote:What is the fastest booting Linux OS for the Pi?
- Raspberry Pi Engineer & Forum Moderator
- Location: The unfashionable end of the western spiral arm of the Galaxy
It will depend on what you consider an OS. A stripped down kernel can boot almost instantly. Then you can keep adding 'stuff' and it will scale.
A less pedantic, but incorrect answer, would be ArchLinux.
Edit: It occurs to me that you asked which OS rather than which distro. In that case I'd say RiscOS or some bare metal OS. I suppose they're all bare metal, but you know what I mean.
It's an old thread, but the issue remains exactly the same..DougieLawson wrote:Why is it important?Pingpong1109 wrote:What is the fastest booting Linux OS for the Pi?
Mine model A+ takes about a minute to boot - way too long for me as it will run a battery powered [*] cycling computer. Is Arch with (ugh, dirty word..) systemd the distro with fastest boot time?
[*] If I can boot it within, let's say 10 s I could implement some sleep option with an accelerometer triggering wake up action.
Tiny Core Linuxprzemof wrote:It's an old thread, but the issue remains exactly the same..DougieLawson wrote:Why is it important?Pingpong1109 wrote:What is the fastest booting Linux OS for the Pi?
http://forum.tinycorelinux.net/index.ph ... ,57.0.html
http://distro.ibiblio.org/tinycorelinux/ports.html
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
There will be an awful lot of fluff being booted if you are using standard Rasbian, that isn't needed on a bike computer. You can either take Raspbian and remove what you don't need, or create a new rootfs from scratch using buildroot. You'll need to google for how to do that one!
If you use raspbian, it's probably best to start small and install what you need, rather than try to hunt down what you don't.
https://github.com/debian-pi/raspbian-ua-netinst
Thanks for the replies! I'll try to provide some test results later.
Current boot time to fully functional sytem, with my cycling computer running on class 4 SD card is 39.8s from cold start.
Aaah, friday afternoon, I will take a bite of the bait as I am so bored and intent on avoiding doing something useful I resort to playing table tennis.Pingpong1109 wrote:What is the fastest booting Linux OS for the Pi?
I feel condescending yet ambivalent whenever I try to answer any question, I am sure you could answer this yourself with google, and I see that every other answer is wrong and yet also correct at the same time.
If you gave some more info maybe a more useful answer could be given?, Of course maybe you are being terse as you do not want to give away the world changing idea that will make you rich?
Simple answer is raspbian is the fastest, all you need to do is remove the init system and recompile a minimal speed optimised kernel then drop straight from kernel boot into your specialised application code or a minimal shell.
But really you need to know what you want to achieve with your project, benchmark the hardware and workout where any bottle necks are, then profile the kernel code, workout what services you require and what dependencies everything has, then you can optimize.
I remember years back running everything from a compressed ram disk because decompression was faster than reading the same data from disk, I use that as illustration that there are many ways of optimizing based on the many types and speeds of hardware that may be available in a system, so you need to look at benchmarking everything and working out time costs of everything (cache,ram,disk, bus transfers, cpu avaialable, coprocessors available). Also looking at dependencies and what can be delayed and what cannot, things like dhcp net config often takes a long time and disk access is probbly slowest factor.
I have heard a rumor that there could be vast improvements in rpi speed soon as someone is working on a gcc plugin for compiling vc4 native assembly from standard c and there is a vc4 Massalin Synthesis kernel for fast path linux bytecode.
So there's is my 2 pennys worth, 2p or not 2p is that the question?
Using a minimal buildroot system to just launch a single application can be very quick. This looks like about 4 seconds from boot to game starting.
mung,
It is said that installing systemd as a replacement init system speed things up. No idea really I have not tried it much.
Best to start with getting rid of all the services started at boot up that you don't need.
What on Earth are you talking about? Google is not helping me much. Sounds like .NET run time stuff or something. Not much to do with boot time I think as there is precious little of that involved in starting up a Linux machine.gcc plugin for compiling vc4 native assembly from standard c and there is a vc4 Massalin Synthesis kernel for fast path linux bytecode.
+1fruitoftheloom wrote: Tiny Core Linux
Real life is, to most, a long second-best, a perpetual compromise between the ideal and the possible.
Meanwhile, the sysadmin who accidentally nuked the data reckons "its best not run anything more with sudo today"
what about spike milligan?
Thanks again for the replies! The details:
I'm working on an open cycling computer written in python, based on pygame running on model A+. The display is PiTFT capacitive, so I don't care about GPU (gpu_mem set to 32MB, HDMI will be switched off). The framebuffer is handled directly from pygame, so no xorg required. The device will be battery powered, so I want to have 0
boot time, but the code won't be heavy, so when started I won't need a lot of processing power. There will be minimal disc activity (1 write/s, ~1 MB/hr of data, much more in debug mode). Currently there are a few sensors connected:
- gps chip (serial) - that's why I need gpsd,
- pressure/temperature sensor (SPI),
- accelerometer (I2C),
- future: bluetooth (BLE) connectivity.
I also use custom splash screen, based on fbi, but that might end up in framebuffer kernel module later on. Right now it's a service.
I need networking (over wifi), because of ssh, but that won't be required when the device is ready.
I'm waiting for CL10 SD card (currently CL4). I did a run test with bootchart and CPU is almost maxed out during boot.
Important part of config.txt:
BTW initial_turbo doesn't seem to make any difference, but I didn't try to investigate it yet.
initial_turbo=30
arm_freq=1000
arm_freq_min=700
core_freq=500
sdram_freq=500
over_voltage=6
Bootchart : http://www.bootchart.org/samples.html might shed some light on this claim .....Heater wrote: It is said that installing systemd as a replacement init system speed things up. No idea really I have not tried it much.
For speed first i would try passing the kernel option init=/path/to/your/app it might work !
I guess you don't really need gpds. Just read the GPS data stream from the UART directly and parse out the information you want.
That won't save much boot time but every little helps, right?
In the extreme write the app in C++ using Qt. That saves the overheads of loading the Python run time.
r3d4
Those bootcharts are useless. Most of them are over 10 years old so are probably irrelevant today. Especially systemd was not around then.
As usual, the answer is "it depends"
Standard NOOBS raspbian image provided is of course relatively slow to boot(30 seconds),
Simply moving to Archlinux will get you under 10 seconds, with minimal messing
(many due to init/systemd difference)
Just examples , & ... http://www.bootchart.org/docs.htmlHeater wrote:r3d4
Not that i have tried to set it up but AFAIK it should still work , all though it appears not to have been updated recentyHow it Works
Logger Startup
The boot logger (/sbin/bootchartd) is run by the kernel instead of /sbin/init. This can be achieved by modifying the GRUB or LILO kernel command line, e.g.:
/boot/grub/menu.lst
title Fedora Core (2.6.10) - bootchart
root (hd0,1)
kernel /vmlinuz-2.6.10 ro root=/dev/hda1 init=/sbin/bootchartd
initrd /initrd-2.6.10.img
EG : http://i46.tinypic.com/29xjc4w.png
If anyone wants to put it to the test ? ..
+ It seams to still be in use http://forum.tinycorelinux.net/index.php?topic=8627.0
++ Hear is a Request : "Bootchart from a pi" http://forum.tinycorelinux.net/index.php?topic=14242.0
- mahjongg
- Forum Moderator
The "fastest booting OS" is the one that spends the least time transferring data from the card into memory, running the least amount of code to "boot", and spending the least amount of time initializing sub-systems. its as simple as that.
No, Arch Linux took me about 17 seconds.mikerr wrote:As usual, the answer is "it depends"
