Hi guys,
I am trying to max out my raspberry pi. I have a USB3 16gb flashdrive, Class 10 8gb sandisk SD, 1.5 amp power supply, heatsinks and a fan, running frodo. It is currently running at 109F playing a 1080 movie with 97-100% cpu usage and around 25% memory.
Can I dedicate more RAM to the GPU?
Is there a way to speed up the LAN transfer, it seems like it skips frames sometimes.
What other settings can I change to max it out?
Here are my settings:
# default GPU memory split (do not change if you do not know what you are doing)
gpu_mem=128
# SDRAM size based GPU memory split, uncomment and setup to override 'gpu_mem'
gpu_mem_256=100
gpu_mem_512=128
# Overclocking settings
# WARNING: Do not change/enable if you do not know what you are doing!
# The System may become unstable or you can have data corruption or
# you can loose your warranty if you set wrong settings
# please read: http://elinux.org/RPi_config.txt#Overclo...figuration
# Overclock mode settings.
# default recommended values are: arm_freq | core_freq | sdram_freq | over_voltage
# no overclocking : 700 | 250 | 400 | 0
# mode 'Modest' : 800 | 300 | 400 | 0
# mode 'Medium' : 900 | 333 | 450 | 2
# mode 'High' : 950 | 450 | 450 | 6
# mode 'Turbo' : 1000 | 500 | 500 | 6
arm_freq=1100
core_freq=550
h264_freq=300
isp_freq=0
v3d_freq=300
sdram_freq=600
over_voltage_sdram=6
over_voltage=8
temp_limit=176
avoid_pwm_pll=1
# set to 'force_turbo=1' to disable dynamic overclocking (you can lose your warranty!)
force_turbo=1
# If you have any data corruption using Turbo Mode and overclocking
# try with this setting uncommented
# If this still fails, try to use Medium mode without "over_voltage=2"
# If it ultimately keeps failing, forget about this until it gets fixed
# Use a more conservative mode that will works fine in any cases:
# initial_turbo=30
# Overscan settings
# Make display smaller to stop text spilling off the screen
# see also http://www.raspberrypi.org/phpBB3/viewto...67&t=15700
# overscan_scale=1
# disable_overscan=1
# Adapt overscan values to your needs
# overscan_left=57
# overscan_right=59
# overscan_top=20
# overscan_bottom=20
# various settings see also: http://elinux.org/RPi_config.txt
# Force HDMI even if unplugged or powered off
# hdmi_force_hotplug=1
# License keys to enable GPU hardware decoding for various codecs
# to obtain keys visit the shop at http://www.raspberrypi.com
# decode_MPG2=0x00000000
# decode_WVC1=0x00000000
# decode_DTS=0x00000000
# decode_DDP=0x00000000
# End of default configuration
# all values below this line were inserted from config.txt.bk (your old config)
# and can be merged with the above values
