Zakki
Screw Type Terminal Block for GPIO...
Wed Mar 26, 2014 4:13 pm
I want to be able to snap a screw type terminal block onto the 2x13 GPIO connector so I can easily attach wires instead of using female prototyping wires. The case that I am enclosing everything into isn't big enough for a breadboard so the terminal blocks would be best for me. Here is an example of what I am looking for but it only has 12 pins...
http://www.ebay.com/itm/10pcs-12-Poles- ... 1186765770
That terminal also has male pins on the bottom... Do you know of any with female connectors on the bottom so I don't have to use a female to female connector before the terminal?
Another option I was looking at is the adafruit prototyping board...
http://www.adafruit.com/products/801
But I was hoping to avoid soldering it together.
Thanks for the help,
Zac
JoeDaStudd
Re: Screw Type Terminal Block for GPIO...
Thu Mar 27, 2014 10:35 am
I've never seen screw terminals with female ends as they are designed for soldering onto PCB, the weight and stress on 0.1" header wouldn't be too wise.
The cheapest and easiest way would be to solder it yourself using some 0.1" headers, strip or proto board and screw terminal blocks, of course you still have the issue with weight and stress on the GPIO.
This is pretty similar however size wise your not going to be saving much room if any over standard jump leads.
Or a standard GPIO to 26pin ribbon with a breakout.
Zakki
Thu Mar 27, 2014 5:35 pm
Thanks for the reply. I did see that product as I was searching and it would take up too much space. I think going with the adafruit protoboard will be my best option. I did however find a couple places that seem to have the same thing, but already soldered and for less money...
http://www.tinyosshop.com/index.php?rou ... uct_id=622
http://usd.dx.com/product/diy-raspberry ... zRhHtzw6Zg
I don't think either of those companies have stock in the US so international shipping will take a while. Last time I ordered from DX it took a month to receive my relay board :(
Zac
alexeames
Thu Mar 27, 2014 6:29 pm
Something like this perhaps? Or have I got the wrong end of the stick?
Alex Eames RasPi.TV, RasP.iO
Zakki
Fri Mar 28, 2014 12:08 am
That looks promising... Got a link?
Fri Mar 28, 2014 8:27 am
Zakki wrote:That looks promising... Got a link?
There's one printed on the board http://rasp.io/breakoutpro
Zakki
Fri Mar 28, 2014 11:57 am
Man that is expensive to get shipped to the US. It ended up being over $75 for two boards and international shipping. Not exactly worth it to me!
Anyone in the USA have something similar?
Fri Mar 28, 2014 8:04 pm
Zakki wrote:Man that is expensive to get shipped to the US. It ended up being over $75 for two boards and international shipping. Not exactly worth it to me!
Alex has said he's going to have a US distributor selling the Rasp.io boards soon.
This is a doctor free zone.
alexeames
Sat Mar 29, 2014 9:27 am
Indeed. Cyntech has a US branch, but no stock yet. We only launched this last week. You can't go global instantly (in a new product range when you don't know how much demand there is) with something like this.
MCM has also expressed an interest, so we'll see what develops out of that.
JasGot
Mon Aug 31, 2015 8:30 pm
Just found this. I'm considering its usefulness......
https://www.winford.com/products/brk2x20.php
