soydepr
X11 librsaries
Mon Mar 24, 2014 10:53 am
want to install a lighter browser dillo, but when installing flak i get this error
Configure could not find required X11 libraries
KeithSloan
Re: X11 librsaries
Mon Mar 24, 2014 6:39 pm
On my Raspberry Pi where I have a number of X11 applications I have
dpkg --get-selections | grep x11
dbus-x11 install
gsfonts-x11 install
libx11-6:armhf install
libx11-data install
libx11-dev:armhf install
libx11-doc install
libx11-xcb1:armhf install
x11-apps install
x11-common install
x11-utils install
x11-xkb-utils install
x11-xserver-utils install
x11proto-core-dev install
x11proto-input-dev install
x11proto-kb-dev install
soydepr
Re: X11 librsaries
Tue Mar 25, 2014 11:04 am
Found out yum install Dillo does it
plugwash
Re: X11 librsaries
Tue Mar 25, 2014 6:11 pm
Just FYI the general assumption round here is that people will be running raspbian unless stated otherwise. If you are using something else (as clearly you are) it's best to either post in the distro specific forum for your distro or state which distro you are using.
soydepr
Re: X11 librsaries
Wed Mar 26, 2014 12:13 am
Thanks. Appreciate that advice
