Keyboard layout
Posted: Fri Mar 21, 2014 3:35 am
Cant get the @ to come up after hitting shift+@
A small, affordable computer with free resources to help people learn, make things, and have fun
https://www.raspberrypi.org/forums/
https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=72665
(Using Raspbian) the Pi defaults to UK keyboard layout - I guess you're using a US keyboard (?). The "Internationalisation Options" of raspi-config (sudo raspi-config from the command line) is where you go to change that etc.Stanley07 wrote:Cant get the @ to come up after hitting shift+@
So then I need to set the keyboard to Uk, correct? I have a Acer keyboard , I think its 105 keys, does that make a difference from being 104 keys?FTrevorGowen wrote:(Using Raspbian) the Pi defaults to UK keyboard layout - I guess you're using a US keyboard (?). The "Internationalisation Options" of raspi-config (sudo raspi-config from the command line) is where you go to change that etc.Stanley07 wrote:Cant get the @ to come up after hitting shift+@
Trev.
No - you need to tell Raspbian what (country) type of keyboard (layout) you're actually using (via raspi-config). So, if the '2' key, shifted is '@', and the '3' key shifted is '#', etc. your keyboard layout is US (a UK keyboard would have '"' and '£' instead, plus other differences). There are also options to select the number of keys present. However, for the US style mini-keyboard** I use I "lied" - it lacked the "numeric keypad" a 104/5 keyboard has but, since those keys are "duplicates", it didn't matter.Stanley07 wrote:So then I need to set the keyboard to Uk, correct? I have a Acer keyboard , I think its 105 keys, does that make a difference from being 104 keys?FTrevorGowen wrote:(Using Raspbian) the Pi defaults to UK keyboard layout - I guess you're using a US keyboard (?). The "Internationalisation Options" of raspi-config (sudo raspi-config from the command line) is where you go to change that etc.Stanley07 wrote:Cant get the @ to come up after hitting shift+@
Trev.
