errazzor
Re: Controlling LAN LEDs individually
Fri Sep 15, 2017 10:25 am
The script works like a charm on a Pi 3 !
i did the same what dom wrote above.
Absolutely perfect, THANKS VERY MUCH to all here ! This is a mandatory function for me, because the Pi3 is in my bedroom.
Turning off all LEDs should be a standard function, i really dont understand why this is not possible out-of-the-box!
Cheers!
kara
Thu Mar 15, 2018 8:04 pm
i get this error when trying to make on rpi3
gcc -lusb llctl.c -o llctl
llctl.c:10:17: fatal error: usb.h: No such file or directory
 #include <usb.h>
compilation terminated.
Makefile:7: recipe for target 'all' failed
make: *** [all] Error 1
rpdom
Thu Mar 15, 2018 8:25 pm
Did you install libusb-dev?
kara
Thu Mar 15, 2018 9:22 pm
er...... no.....
(works fine now)
*gets coat ;)
djace
Wed Mar 21, 2018 10:09 pm
I'm currently getting, on the Raspberry Pi 3 Model B+:
Segmentation fault
GamerGun
Tue May 01, 2018 8:27 pm
Segmentation fault
Yep same here..
dom
Tue May 08, 2018 6:21 pm
​There is an dtparam that can control led behaviour - see https://github.com/raspberrypi/firmware ... EADME#L96​
It was added March 21, so requires a kernel newer than that date.
allfox
Tue May 08, 2018 8:30 pm
Would this work for Pi 3 v1.2 ?
Because mine still keep blinking after I add
dtparam=eth_led0=14
dtparam=eth_led1=14
to /boot/config.txt
I did a rpi-update to 4.14.39-v7+ May 5, not help.
PhilE
Sat May 12, 2018 10:18 am
This is currently a Pi 3B+-specific feature. The default LED modes weren't very useful so we had to change the LAN7800 driver anyway, and making the modes user-selectable was a simple extension.
bensimmo
Sat May 12, 2018 11:09 am
Any plans to bring it to the older ones as I need it (just to make it easier) on B/B+ (v1) as they make good camera pi.
If not, could you add a note to the readme that it's 3B+ only (or7800).
quadrplax
Sun Jul 29, 2018 12:43 am
I'm guessing this won't work on the Raspberry Pi 3 Model B+ due to the new gigabit ethernet chip? I tried to compile and run it (with sudo), and all I get are segmentation faults.
Paul Webster
Contact: Twitter
Sun Jul 29, 2018 6:01 am
See the posts before yours for a different solution for 3B+
errazzor
Fri Aug 10, 2018 12:39 pm
RPI 3 B+ disabling Network LEDs with dtparm worked fine but...
Is there an option a Raspberry 3 B+ for disabling the power and activity LED with dtparm?
Couldnt find a parameter for them....
Msprg
Mon Feb 04, 2019 12:31 pm
HI,
a bit late, but if you still did not found the answer:
Just add these lines before
exit 0
line of the /etc/rc.local
#Power LED off
echo none > /sys/class/leds/led1/trigger
echo 0 > /sys/class/leds/led1/brightness
#Activity LED off
echo none > /sys/class/leds/led0/trigger
echo 0 > /sys/class/leds/led0/brightness
This should disable the leds altogheter during the bootup.
raspmod
Tue Apr 23, 2019 12:44 am
mcduman wrote:
Sun Mar 26, 2017 11:57 am
Yep it works. I saw a new commit at github though dated February 2017 (https://github.com/dradermacher/lan951x-led-ctl) downloaded and compiled it but could not get it to work
Ditto
I did
root@raspberrypi:~/git#  apt-get install libusb-dev
root@raspberrypi:~/git# make
strip llctl
root@raspberrypi:~/git# ./llctl f0 l0 d0
Segmentation fault
I downloaded the file from this post.
Linux raspberrypi 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux
Smrtka
Thu Jun 11, 2020 3:18 pm
(double post please delete)
Smrtka
Thu Jun 11, 2020 3:32 pm
Did anyone test this on RPI 4 ? and if so can I please get step by step guide as I am not very good at Linux, I am running the new Raspbian OS, managed to get the ACT and PWR leds to be off but the ETH0 is quite strong leds and blinking
no3rpi
Fri Jun 12, 2020 6:06 am
for rpi4 add this to boot config.txt
# Turn OFF Network LED's
dtparam=eth_led0=14
dtparam=eth_led1=14
RPI3^2 + RPI4 = :idea:
