av8tor
2 Sound Cards Streaming Audio from 1 Raspberry Pi almost.
Thu Mar 13, 2014 3:08 pm
I am trying to use one Raspberry to stream 2 different audio sources to an Icecast server.
I have 1 stream working perfectly.
I have one Darkice.cfg file setup for device = plughw:0,0 and a second Darkice.cfg file setup for device plughw:1,0
I can have either Darkice / sound card playing perfectly however when I try to start up a second Darkice using the second sound card the audio on both streams gets very chopping and it sounds like the audio is playing faster (kind of like a Mickey Mouse sound).
Any Suggestions?
George
av8tor
Re: 2 Sound Cards Streaming Audio from 1 Raspberry Pi almost
Thu Mar 13, 2014 3:53 pm
After doing more research and experimenting I found my own answer. In case others are having same problem with 2 sounds cards here is the answer.
Edit /boot/cmdline.txt and add the highlighted piece:
dwc_otg.lpm_enable=0 dwc_otg.speed=1 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
