webiopi config file
Posted: Mon Mar 10, 2014 5:28 pm
by lilzz
[GPIO]
# Initialize following GPIOs with given function and optional value
# This is used during WebIOPi start process
#21 = IN
#23 = OUT 0
#24 = OUT 0
#25 = OUT 1
what's are those 0 and 1 after the OUT?
[DEVICES]
# Device configuration syntax:
# name = device [args...]
#   name   : used in the URL mapping
#   device : device name
#   args   : (optional) see device driver doc
# If enabled, devices configured here are mapped on REST API /device/name
# Devices are also accessible in custom scripts using deviceInstance(name)
# See device driver doc for methods and URI scheme available
# Raspberry native UART on GPIO, uncomment to enable
# Don't forget to remove console on ttyAMA0 in /boot/cmdline.txt
# And also disable getty on ttyAMA0 in /etc/inittab
#serial0 = Serial device:ttyAMA0 baudrate:9600
# USB serial adapters
#usb0 = Serial device:ttyUSB0 baudrate:9600
#usb1 = Serial device:ttyACM0 baudrate:9600
#temp0 = TMP102
#temp1 = TMP102 slave:0x49
#temp2 = DS18B20
#temp3 = DS18B20 slave:28-0000049bc218
so from above, temp0 is the name, TMP102=device[args..] what's args in this case?
looks like an array format.
ROUTES]
# Custom REST API route syntax :
# source = destination
#   source      : URL to route
#   destination : Resulting URL
# Adding routes allows to simplify access with Human comprehensive URLs
# In the next example with have the bedroom light connected to GPIO 25
# and a temperature sensor named temp2, defined in [DEVICES] section
#  - GET  /bedroom/light       => GET  /GPIO/25/value, returns the light state
#  - POST /bedroom/light/0     => POST /GPIO/25/value/0, turn off the light
#  - POST /bedroom/light/1	   => POST /GPIO/25/value/1, turn on the light
#  - GET  /bedroom/temperature => GET  /devices/temp2/temperature/c, returns the temperature in celsius
#/bedroom/light = /GPIO/25/value
#/bedroom/temperature = /devices/temp2/temperature/c
#/livingroom/light = /devices/expander0/0
#/livingroom/brightness = /devices/adc/0/float
#/livingroom/temperature = /devices/temp0/temperature/c
So, GET /bedroom/light=source and GET /GPIO/25/value=destination?
