nerd7473
Powering a 7" 9v LCD display from 5v
Wed Mar 05, 2014 7:26 pm
I want to power a lcd for a project but I want the battery to power both the pi and the display I have rca input and it runs on 9v to 12v at one amp. Is there anything I can use to boost the voltage and amperage?
nerd7473
alexeames
Re: Powering a 7" 9v LCD display from 5v
Wed Mar 05, 2014 9:50 pm
Does your display actually need 9V or is it regulated down somewhere on the board?
If not, you might be able to hack it and run the whole lot from 5V.
Alex Eames RasPi.TV, RasP.iO
nerd7473
Thu Mar 06, 2014 2:34 am
alexeames wrote:Does your display actually need 9V or is it regulated down somewhere on the board?
It says 9v-12v at 1a at 2.5a max so I have no clue
nerd7473
nerd7473
Thu Mar 06, 2014 2:38 am
I have no idea if it is regulated down the board or not
nerd7473
klricks
Thu Mar 06, 2014 2:46 am
Here is a thread about converting a small screen to run on 5V. You would really have to know what you are doing to accomplish this:
http://www.raspberrypi.org/forum/viewto ... 1&start=75
Generally is is much easier and more efficient to step down DC voltage than to step up. If it were me I would use a 12V battery for the screen and then step down to 5V for the RPi using a 'buck' or switching type regulator.
You can get a simple cheap converter by using a car USB adapter with a 12V battery.
nerd7473
Thu Mar 06, 2014 1:00 pm
klricks wrote:Here is a thread about converting a small screen to run on 5V. You would really have to know what you are doing to accomplish this:
I would rather use the buck converter because I am making a raspberry pi laptop I am almost done with the bottom half except for a battery
nerd7473
nerd7473
Thu Mar 06, 2014 10:08 pm
I would like to say that I have posted another question in another part of the forum:
http://www.raspberrypi.org/forum/viewto ... 49#p516049
nerd7473
