CAP_Cadet
SOLVED: Separate GNDs for Different Voltages?
Wed Mar 05, 2014 5:32 pm
I am using my Pi's GPIO to control some 12V lighting strips (LED). Can I just ground the GPIO connection to the 12V supply's ground? Or do I have to keep the RPi's connection grounded back to the board? I have heard that using 12V to GND 3.3V can create negative voltage, but I don't know.
Thanks!
Joseph Anand
redhawk
Re: Separate GNDs for Different Voltages?
Wed Mar 05, 2014 5:42 pm
If your power supply / regulator shares a "common" ground with the Pi then ground is ground via the GPIO ground pins
Richard S.
FTrevorGowen
Wed Mar 05, 2014 5:46 pm
CAP_Cadet wrote:Hello,
Thanks!
The Pi's Gnd (0V) should be connected to the Gnd (0V) that 12V is "referenced" to (just like the Pi's 5V and 3V supply rails share a common Gnd (0V)). However, make sure that none of the GPIO pins can connect to the 12V ie. they should be isolated via a transistor or other buffer circuit.
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
CAP_Cadet
Wed Mar 05, 2014 6:00 pm
Thanks for the quick replies.
The GPIO pins are using a transistor to control a 5V signal (from the Pi) to switch a 5V relay which turns on/off the 12V strip. I'll put up a schematic in a bit.
Thanks again for the help.
Joseph Anand
Wed Mar 05, 2014 6:24 pm
I assume you mean a 3.3V signal from the Pi which drives transistors that control a 5V line to drive the relays which switch 12V.
If so, then you don't need to connect anything on the 12V side to the Pi as the relays will keep the two sides of the circuit isolated.
But please do post the schematic to confirm this.
hampi
Wed Mar 05, 2014 6:28 pm
It is better to avoid that the current from 12 V circuit flows through the RPi supply ground line. The circuit '12 V -- switch -- load -- ground' can have extra noise and transients from switching the load on/off. Usually this means that the more sensitive computer ground and the power circuit grounds are connected together only at one place (ground loops to be avoided). Analog signals are even more sensitive for grounding.
CAP_Cadet
Wed Mar 05, 2014 7:52 pm
Schematic as promised.
@rpdom you are exactly right.
edit: the relay is in open mode
Joseph Anand
CAP_Cadet
Wed Mar 05, 2014 8:44 pm
Thanks for all your help everybody. I went with what was on my schematic and it is working well. :D
I will be posting my latest project's overview next week.
Thanks again!
For those who want to know the solution: Keep your RPi grounding separate from your higher-voltage line's grounding.
Joseph Anand
