My Wifi adapter acting unstable during different boot times.
Posted: Wed Feb 26, 2014 2:13 pm
by lilzz
Sometimes when it booted up it functioned successfully and acquired IP address
but sometimes it cannot acquire the IP address from the network.
My network is up all the time. I don't why this is happening.
Is there a script I can put in so that it can 100% guarantee wifi adapter can acquire IP address each time the Pi booted?
Re: My Wifi adapter acting unstable during different boot ti
Posted: Wed Feb 26, 2014 4:14 pm
by allfox
I have two suggestions:
1 - Uninstall ifplugd. I was confused when sometime I could acquire an IP, sometime I just can't, until I purge this thing.
2 - If you plug wifi adapter in pi's USB directly , check your power supplier.
Posted: Thu Feb 27, 2014 5:14 am
by lilzz
allfox wrote:I have two suggestions:
how to uninstall ifplugd?
i try rename ifplugd ifplugd_old but it says Barewood "ifplugd not allowed while "strict subs in use.
Posted: Thu Feb 27, 2014 8:35 am
by allfox
When you want to install something:
sudo apt-get install [something's name]
When you want to uninstall something:
sudo apt-get remove [something's name]
And your error message sounds from perl, are you using a perl script to rename things? You could use the mv command~ ;)
