szahran
RPi Battery Pack
Mon Feb 17, 2014 2:14 pm
Hello Everyone,
I have a project where I need my RPi to be in a mobile environment, for this I need a battery pack that can supply my RPi with enough power for many hours, in addition I have a USB hub connected to the RPi which also requires electricity.
I wonder if you can recommend a battery pack that can support both RPi and the USB-hub.
I also need a mini/small/portable HDMI monitor that can work with the RPi.
Thanks in advance,
szahran
MrBunsy
Re: RPi Battery Pack
Mon Feb 17, 2014 2:22 pm
Do you want to buy a complete solution, or are you happy to do some soldering yourself?
szahran
Mon Feb 17, 2014 2:28 pm
It depends on how complicated the soldering is, I don't have electrical engineering background.
I found this thing http://www.adafruit.com/products/1566#Distributors but I'm not sure if it is what I'm looking for.
Please post your suggestions.
MrBunsy
Mon Feb 17, 2014 3:43 pm
That certainly looks like it'd do what you want. What I've done for my pi-on-a-robot is buy a cheap 12v lead acid battery and a regulated DC-DC converter to bring that down to 5V, but I can't currently find the exact converter I used.
MrBunsy
Mon Feb 17, 2014 3:44 pm
szahran
Mon Feb 17, 2014 4:10 pm
Thanks! It seems to be an interesting solution, would you please elaborate on how you've assembled your solution and what things you've exactly used.
MrBunsy
Mon Feb 17, 2014 4:48 pm
I stuck (I think, I'll have to go and track down my notes or circuit board to confirm) the capacitors on the input and out put that the datasheet recommended.
MrBunsy
Tue Feb 25, 2014 7:07 pm
I had an idea the other day - a lead acid battery and an in-car cigarette lighter USB socket might be sufficient. Depends how well regulated it is.
