titsmiggee
Griffin iMic audio-capture with Audacity
Thu Feb 06, 2014 6:09 pm
Hello! I am 100% noobtastic and would love to hear your advice! Here is my problem:
I am trying to record an audio sample for a music project I am doing, and I am currently using a USB iMic for audio capture through Audacity. The recording device shows up on the software's drop-menu, and the record button works in time as if it were recording, however I am receiving no audio, just flatline. I've read on forums that the iMic is a verified device working on the Pi, but cannot find the code to set it as the default/primary/functioning audio capture device.
If anyone has insight on how to fix this problem, it would be greatly appreciated.
tvjon
Re: Griffin iMic audio-capture with Audacity
Thu Feb 06, 2014 7:56 pm
"but cannot find the code to set it as the default/primary/functioning audio capture device. "
It should automagically be found, as seen in attached pic'.
Bear in mind the switch should be pointing to the headphone socket, not the mic' input!
In a LxTerminal window, type:
sudo lsusb -v
& look for:
Bus 001 Device 009: ID 077d:07af Griffin Technology iMic
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x077d Griffin Technology
idProduct 0x07af iMic
bcdDevice 0.06
iManufacturer 1 Griffin Technology, Inc
iProduct 2 iMic USB audio system
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 344
bNumInterfaces 3
bConfigurationValue 1
iConfiguration 3 D3 2003/10/30 09:27
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 0
iInterface 0
AudioControl Interface Descriptor:
bLength 10
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 1.00
wTotalLength 78
bInCollection 2
baInterfaceNr( 0) 1
baInterfaceNr( 1) 2
bLength 12
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 12
wTerminalType 0x0101 USB Streaming
bAssocTerminal 11
bNrChannels 2
wChannelConfig 0x0003
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 13
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 1
bSourceID 12
bControlSize 2
bmaControls( 0) 0x55
bmaControls( 0) 0x01
Mute Control
Bass Control
Treble Control
Automatic Gain Control
Bass Boost Control
bmaControls( 1) 0x02
bmaControls( 1) 0x00
Volume Control
bmaControls( 2) 0x02
bmaControls( 2) 0x00
Volume Control
iFeature 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 14
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 1
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 11
wTerminalType 0x0201 Microphone
bAssocTerminal 12
bNrChannels 2
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 13
bDescriptorType 36
bUnitID 6
bSourceID 11
bControlSize 2
bmaControls( 0) 0x03
bmaControls( 0) 0x00
Mute Control
Volume Control
iFeature 0
bLength 9
bDescriptorType 36
bTerminalID 13
bAssocTerminal 0
bSourceID 6
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
AudioStreaming Interface Descriptor:
bLength 7
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 12
bDelay 0 frames
wFormatTag 1 PCM
bLength 14
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bNrChannels 1
bSubframeSize 2
bBitResolution 16
bSamFreqType 0 Continuous
tLowerSamFreq 6400
tUpperSamFreq 48000
Endpoint Descriptor:
bLength 9
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 9
Transfer Type Isochronous
Synch Type Adaptive
Usage Type Data
wMaxPacketSize 0x0064 1x 100 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
AudioControl Endpoint Descriptor:
bLength 7
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x01
Sampling Frequency
bLockDelayUnits 2 Decoded PCM samples
wLockDelay 1 Decoded PCM samples
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 12
bDelay 0 frames
wFormatTag 1 PCM
bLength 14
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tLowerSamFreq 6400
tUpperSamFreq 48000
bLength 9
bDescriptorType 5
bmAttributes 9
Synch Type Adaptive
Usage Type Data
wMaxPacketSize 0x00c8 1x 200 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x01
Sampling Frequency
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 13
bDelay 0 frames
wFormatTag 1 PCM
bLength 14
bDescriptorType 36
bNrChannels 1
bSubframeSize 1
bBitResolution 8
tLowerSamFreq 6400
tUpperSamFreq 48000
bLength 9
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 9
Synch Type Adaptive
Usage Type Data
wMaxPacketSize 0x0032 1x 50 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x01
Sampling Frequency
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 2
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 13
bDelay 0 frames
wFormatTag 1 PCM
bLength 14
bDescriptorType 36
bNrChannels 1
bSubframeSize 2
bBitResolution 16
tLowerSamFreq 6400
tUpperSamFreq 48000
bLength 9
bDescriptorType 5
bmAttributes 9
Synch Type Adaptive
Usage Type Data
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x01
Sampling Frequency
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 3
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 13
bDelay 0 frames
wFormatTag 1 PCM
bLength 14
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tLowerSamFreq 6400
tUpperSamFreq 48000
bLength 9
bDescriptorType 5
bmAttributes 9
Synch Type Adaptive
Usage Type Data
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x01
Sampling Frequency
Device Status: 0x0001
Self Powered
HTH
scruss
Thu Feb 06, 2014 8:58 pm
Aha! Seems that tvjon and I had the same idea. He saved me uploading nearly identical stuff.
Are you sure you have the microphone plugged into the IN socket? Does the microphone work elsewhere?
tvjon wrote:Bear in mind the switch should be pointing to the headphone socket, not the mic' input!
The older one that I have has a weird slider for Line/Mic levels. It either points to Line, or not-quite-points-to Line.
I also noticed glitches if you record at 44.1. 48 kHz works fine.
Pronouns: he/him
titsmiggee
Thu Feb 06, 2014 11:07 pm
I have it set to "Line" (the slider) and to "In" (rather than "out")
Yes, the iMic works with a PC just fine. With the RPi, I only get a flat blue line, no audio signal being processed through the machine.
I will try again when I get home and relay the code I receive from the terminal.
titsmiggee
Fri Mar 21, 2014 3:28 am
I got it to work, thank you very much for the support
