Proxy settings - access net in terminal
Posted: Mon Jan 27, 2014 11:47 am
by Craynerd
Hi
I`m trying to use the raspi from behind a proxy at work (school).
I have followed the following info:
Proxy support for browsers etc…
sudo nano /etc/environment
export http_proxy=”http://YOU.R.IP.ADR:PORT”
Proxy support for APT…
sudo nano /etc/apt/apt.conf.d/10proxy
Acquire::http::Proxy “http://YOU.R.IP.ADR:PORT”;
After doing this, it allowed me to correctly use the apt-get function and browse the web in a browser. However, I am running a script that uploads data to the internet and this is not running correctly! I have tried to ping google:
and get no reply so I am guessing I have no internet access from command terminal!
I am very much a beginner but is it normal not to get a ping from google or is this likely the issue. How can I solve it?
Any help appreciated.
Re: Proxy settings - access net in terminal
Posted: Mon Jan 27, 2014 11:51 am
by redhawk
What happens when you run traceroute 8.8.8.8 ??
Richard S.
Posted: Mon Jan 27, 2014 12:16 pm
by Richard-TX
Proxy's don't let you ping or traceroute to the internet. It is what they do.
If you want to upload to the internet, you have to use an application that is proxy capable.
Setting up a ftp client to use a proxy is not difficult but it can be tricky.
There is one possible gotcha in all this. It is possible that the proxy does not allow protocols other than HTTP.
Proxys really do help in keeping malware away.
Posted: Mon Jan 27, 2014 3:21 pm
by Craynerd
https://github.com/tomhartley/AirPi
This is the code I`m running and it uploads the data to xively. It works fine from home but here in school it fails and I don`t know why. I`ve got all the weather station modules and I really need to get this working or it`ll be a great waste in money!
Posted: Mon Jan 27, 2014 3:25 pm
by redhawk
What kind of proxy is your school running, is it web based only access with user / password authentication??
Richard S.
Posted: Mon Jan 27, 2014 3:52 pm
by Craynerd
Hi, I`m not really clear on networking but if it helps, yes we do have user and pass logins but that is to access the local network. I can get an internet connection by bringing in any device and adding proxy to proxy.oldsch and adding the port 8080. I can then get access to the net on any device not password or username needed.
Also, there is a wireless guest network which apparently has ALL access to the internet just without internal network connection.
I appreciate your help!
EDIT
$ traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 60 byte packets
1 * * *
2 * * *
3 * * *
...... Continues to ..
30 * * *
Back to command prompt.
Posted: Mon Jan 27, 2014 4:17 pm
by keithellis
Can you ping 8.8.8.8 from one of the schools computers. It is most likely the proxy is preventing certain connections, that is what they do. Try using the guest network, that should be unrestricted.
Or talk to your admin to open up the sites you need access to on the proxy.
Posted: Mon Jan 27, 2014 4:55 pm
by Craynerd
I`ve just tried to ping a few websites and google 8.8.8.8 from cmd in windows and on all sites: "request timed out"
I don`t know what the tells us or where to go from here.....!
Any further help would be much appreciated.
Chris
Posted: Mon Jan 27, 2014 4:58 pm
by Craynerd
just also did a tracert google.com:
1. 6ms 4ms 3ms 10.10.10.2
2. * * * request timed out.....
Don`t know if that helps any! To be honest, I just want to send the data being collected on the RasPi to Xively!
Chris
