DominusPi
Tell the RPi to execute a command after a laps of time
Thu Jan 23, 2014 3:20 pm
Hey guys !
So I need to be able to execute any command after a short amount of time. What I imagine is something just like for the shutdown command, where you can put as an option to execute it after x minutes.
Is there an easy way for this ?
Thanks !
Cheers !
RaTTuS
Contact: Twitter YouTube
Re: Tell the RPi to execute a command after a laps of time
Thu Jan 23, 2014 3:34 pm
Covfefe
DominusPi
Thu Jan 23, 2014 4:07 pm
Thanks you !
Cheers !
Steven_Aldrich64
Mon Jan 27, 2014 4:51 am
Check out writing a Bash script. It is really easy to write a short script that would do this.
http://tldp.org/HOWTO/Bash-Prog-Intro-HOWTO.html
Tarcas
Tue Jan 28, 2014 9:21 pm
there are lots of choices for this depending on just what you want to do.
cron if you want it to run on a schedule (i.e. Every day at noon, 48 seconds after every hour, or 11:30 PM every Tuesday and Friday in June, August, and December)
at if you want to schedule it to run once, at a specified time
sleep [seconds] if you want to wait a given number of seconds and execute it at either the command line or in a shell script. (at the command line, you would for instance "sleep 60; echo "One minute elapsed. Shutting down." shutdown -h now" with the semicolon separating your commands.)
