I'm running Raspbian.
You just have to manually start the eth1 interface with
sudo ifup eth1After this manually start browser(Midori) and go to the URL(m.home in my case) which can be found in autostart under Windows.
Then press connect and you are done.
I didn't even have to use external battery for the dongle. But its better if you can have an external supply.
