Safe to use 1/4" 4-40 metal standoffs?
Posted: Sun Jan 19, 2014 12:32 am
by Elliott B
I'm building a case for my model B (rev 2), and I want to use 4-40 metal standoffs at the two mounting holes. These are usually 1/4" diameter hex on the outside, and I'm wondering if that's too big. Meaning, will the metal make contact with any wiring on the board?
Here's an example: http://www.jameco.com/Jameco/Products/ProdDS/77586.pdf
Re: Safe to use 1/4" 4-40 metal standoffs?
Posted: Sun Jan 19, 2014 12:45 am
by Phill Rymer
Elliott B wrote:I'm building a case for my model B (rev 2), and I want to use 4-40 metal standoffs at the two mounting holes. These are usually 1/4" diameter hex on the outside, and I'm wondering if that's too big. Meaning, will the metal make contact with any wiring on the board?
maplins in uk sell plastic ones
Posted: Sun Jan 19, 2014 12:48 am
by Elliott B
I'm aware of nylon standoffs, but I want to use metal. These same spacers will be inserted in a wood case, connected to countersunk screws on the outside, so nylon won't be strong enough.
Posted: Sun Jan 19, 2014 1:01 am
by Paul Moir
I think they'll be too big. There isn't much clearance (sorry, all my rev b boards are in things right now so I can't measure). I used 5mm standoffs and they're fine.
But why so big? I don't think 4-40s will fit the 2.5mm mounting holes anyway.
Posted: Sun Jan 19, 2014 1:09 am
by Elliott B
I've tried a 4-40 screw and it fits perfectly. I suppose M2.5 would fit too, but those seem to be harder to find and more expensive.
For example, DigiKey has 25 options for M2.5 standoffs, and 135 options for 4-40. Easier to find unusual/specific sizes.
Looking at the board, it looks like the corner hole is fine with a 1/4" nut. The other hole (near the micro-USB) has clearance on the bottom, but on the top side, it would touch some nearby traces. I don't know whether those traces are insulated, or if they would contact the nut.
I'm thinking about using metal standoffs below, and nylon nuts on top.
Posted: Sun Jan 19, 2014 1:49 am
by Paul Moir
Ok, good, I was relying on memory there. I couldn't remember if I had tried 6-32 or 4-40. Or maybe it was 3mm.
But a normal 4-40 nut is 3/16" wrench size so about .216 at the corners, so that might be fine anyway, and if not a fiber washer would be a good idea. Speaking of which, can you get a 3/16" standoff? I have a few so someone must make them?
Posted: Sun Jan 19, 2014 10:00 am
by plugwash
Elliott B wrote:I don't know whether those traces are insulated, or if they would contact the nut.
While traces are usually covered with insulating soldermask I don't like to rely on it as you can sometimes chip or scratch your way through it. So if I thought there was any chance of contact between a mounting screw and tracks I would use insulating washers.
