Meyertrix
Execute Python script from Apache
Tue Jan 07, 2014 2:50 pm
Hi, I need some help. I've been struggling for a while now to get a script executed from a local website. I have installed the following:
sudo apt-get install apache2 php5 libapache2-mod-php5
Added to bottom of sudoers file: www-data ALL=(root) NOPASSWD: ALL
Index.html
<html>
<head>
<meta c
</head>
<?php
if (isset($_POST['RightOPEN']))
exec("sudo python /home/pi/test1.py");
if (isset($_POST['LeftOPEN']))
exec("sudo python /home/pi/test2.py");
<form method="post">
<button name="LeftOPEN">Left Door</button>&nbsp;
<button name="RightOPEN">Right Door</button><br>
</form>
</html>
Python script
#!/usr/bin/python
import os
os.system('sudo pihat --id=1 --channel=15 --state=0')
What am i doing wrong? Script executes fine from terminal?
JoeDaStudd
Re: Execute Python script from Apache
Tue Jan 07, 2014 3:02 pm
Do you get any error messages from the php script?
I would guess its an issue with the permissions, the web user would need execution rights which iirc isn't set by default for security reasons.
sudo chmod 777 /var/www
Should work, however I'm rubbish at permissions and I mainly play around offline so security is never a major issue for me.
Meyertrix
Wed Jan 08, 2014 6:48 am
Thanks for the tip. I have executed the command but it is still not working. I also don't care about security as I am running it offline also.
Where do I find a log file to see what the problem or error message is?
Jednorozec
Wed Jan 08, 2014 8:17 am
PHP errors are written to error_log in the directory where the script is. You might want to run <?php phpinfo() ?> to make sure that error reporting is turned on.
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
Wed Jan 08, 2014 8:32 am
Have a look at the files /var/log/apache2/error.log and /var/log/apache2/access.log
Meyertrix
Wed Jan 08, 2014 8:36 am
I am a complete NOOB, can you please explain where to put the <?php phpinfo() ?>. I have tried and no error_log is showing up in the directory.
Meyertrix
Wed Jan 08, 2014 8:49 am
[Wed Jan 08 08:39:48 2014] [error] [client 192.200.111.125] file does not exist: /var/www/favicon.ico
- above is repeated over and over.
192.200.111.125 - - [08/Jan/2014:08:39:48 +0000] "POST / HTTP/1.1" 200 607 "http://192.200.111.123/" "Mozilla/5.0 (BlackBerry; U; BlackBerry 9900; en) AppleWebKit/534.11+ (KHTML, like Gecko) Version/7.1.0.714 Mobile Safari/534.11+"
192.200.111.125 - - [08/Jan/2014:08:39:48 +0000] "GET /favicon.ico HTTP/1.1" 404 502 "-" "Mozilla/5.0 (BlackBerry; U; BlackBerry 9900; en) AppleWebKit/534.11+ (KHTML, like Gecko) Version/7.1.0.714 Mobile Safari/534.11+"
- above is also repeated over and over
192.200.111.125 is the IP of the raspberry
Wed Jan 08, 2014 9:06 am
The "faveicon.ico" message is unimportant. Whenever most browsers visit a website they look for a file called faveicon.ico. This is the icon you can sometimes see in the address bar.
The other messages are a POST, which is usually a form being completed, which was successful (200 status), followed by an attempt to find a faveicon. Neither of these are PHP errors.
If you create a file in /var/www that contains just "<?php phpinfo() ?>", call it test.php for now, then use a browser to access page test.php on your IP address. You should get a long page of PHP information and settings. But error reporting is turned on by default on Debian-based systems like Raspbian.
Meyertrix
Wed Jan 08, 2014 9:16 am
rpdom I am now able to access the PHP info, is there anything I should be looking for as to why this is not working?
Found some info here but not sure how to proceed http://stackoverflow.com/questions/1501 ... eb-browser
Meyertrix
Wed Jan 08, 2014 9:40 am
Okay, just got it working :lol:
What I did was to create a file called home.php under /var/www and coppied my code from index.html above into home.php
I then navigated to it from my browser 192.200.111.123/home.php and it is working 100%
Wed Jan 08, 2014 7:06 pm
Meyertrix wrote:I am a complete NOOB, can you please explain where to put the <?php phpinfo() ?>. I have tried and no error_log is showing up in the directory.
nano /var/www/foo.php
add the <? phpinfo() ?> in there
save it
then point a web browser at http://192.168.xxx.xxx/foo.php
This is a doctor free zone.
revathirevs
Wed Sep 09, 2015 9:56 am
hello friends,
iam trying to run python scripts on apache2. but it only shoing source codes of py scripts.
when iam trying to run .html files , it gives 100% result.
why not with .py ?
remarks: i added addhandler cgi.py to directory
