How to connect Raspberry Pi to computer over Wi-Fi
Hi Guys.I have a problem about connection.I'd like to connect my raspberry pi to my Windows 7 or Ubuntu (Doesn't matter which is) over Wi-Fi.But I couldn't handle it.I need your help.How can i connect my raspberry pi to computer ? Thanks.
Re: How to connect Raspberry Pi to computer over Wi-Fi
I assume you want to control your pi from your windows 7 computer. If this is the case then there are many ways of doing this. My personal fav is using TightVNC witch once installed onto your pi you can access using a VNC viewer meaning you can access your pi's desktop from windows and android etc....
If you only want to access your pi from windows follow this tutorial http://www.neil-black.co.uk/raspberry-p ... sdPNrQ7mNI. Else if you want to access it from an android device too look at my post here http://www.raspberrypi.org/forum/viewto ... 63&t=65264
Good luck, Brookesa05
Thank you for your help.
I recommend PUTTY a great little utility and easy to use.
You could say my love for Linux is terminal
