jackmulmerp
Choosing the best LCD screen
Thu Jan 02, 2014 7:57 pm
I need some help choosing the best LCD for my RPi project(s). At first I though an alphanumeric display would be appropriate but then I changed my mind and decided to go for a graphical LCD.
Some assumptions:
  • I'm rather a newbie when it comes to electronic engineering. I know some basics and I'm not afraid to try something new but I'm not necessarily interested in going off the deep end. An easy solution is obviously preferred :)
  • Anything with resolution around 256x64 would be sufficient.
  • I think I'd prefer getting the LCD and other components and wiring them up together myself. As long as it's not going to be ultra-difficult, of course.
  • I need the LCD to be backlit.
  • As I mentioned before, I need a graphical LCD, not an alphanumeric one.
  • I'm looking for a cheap solution.
  • I'm intending to control the LCD from Python scripts. I that's not possible out of the box, C/C++ should be fine as well. Although, I'm not interested in solutions that would require a custom kernel build - I'd like to it to be universal.
I'd be really grateful if you could point me in the right direction.
Best regards,
Jack
sdjf
Re: Choosing the best LCD screen
Sun Jan 12, 2014 6:47 am
I cannot suggest any particular LCDs for you as the shopping I just finished was for a much larger display, but I can tell you what I did that helped me make my final decision.
I used a search engine to look for all displays with the characteristics I wanted, in addition to searching my favorite mail order sites for what they carried in small monitors.
Then I was overwhelmed by all the possibilities, so I finally made a 3x5 card for each of the final contenders and wrote what I knew about them in a consistent format, so I could stare at the information more easily than using a spreadsheet.
Another important thing is to look at product reviews, see what people who have purchased the displays have to say about them. Amazon is a good place for that kind of review, even if that is not where you are going to make your purchase.
I would start by putting the following into a search engine and see what pops up;
256x64 LCD
But I seem to recall there are suppliers who specialize in kits for what you are talking about, I hope someone else will guide you to those sites! But also hope the above tips might help as well.
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
notro
Wed Feb 12, 2014 4:57 pm
RaspberryPiPc
Thu Jun 26, 2014 1:47 am
http://www.adafruit.com/products/1601I would go with the PiTFT Mini Kit from Adafruit.
Pros / Cons
Pros
  • High quality :!:
  • Touchscreen 8-)
  • Can be programmed via Python or C/C++ :D
Cons
  • Small text but can be changed with LxTerminal :P
  • No more
