robtheplod
RS invited me to order but ......
Wed May 23, 2012 3:04 pm
When i go to the order page everything is in stock except the SSD with the operating system on - presume the Pi isnt much use without this???
grumpyoldgit
Re: RS invited me to order but ......
Wed May 23, 2012 3:06 pm
There is no such animal. You need to do it yourself or buy one on Ebay.
Airstream
Mon May 28, 2012 3:38 pm
There are a number of reputable sellers on eBay with SD cards preloaded with Debian RPi squeeze to get you started. I found the Kingston 8gb SDHC class 4 card with a resized partition to be very good. For example
http://www.ebay.co.uk/itm/8GB-SD-Card-R ... 19d15f3caa
PaulCheffus
Tue May 29, 2012 2:54 pm
grumpyoldgit wrote:There is no such animal. You need to do it yourself or buy one on Ebay.
Hi
If thats the case then I'm not sure what I have just bought?
2000117882 1 4GB SD Card with Raspberry Pi OS installed £9.99
Cheers
Paul
Procrastination - The Thief of Time.
grumpyoldgit
Tue May 29, 2012 3:21 pm
Hi
Cheers
Paul
This is something completely new then. I've not heard of RS or Farnell selling loaded cards. I can't check on it as the RS Raspberry Pi ordering site only allows you in with a valid, unused invite request. That part number does not appear to be valid on their main site. Do they not mention which OS it is?
PaulCheffus
Tue May 29, 2012 3:33 pm
grumpyoldgit wrote: This is something completely new then. I've not heard of RS or Farnell selling loaded cards. I can't check on it as the RS Raspberry Pi ordering site only allows you in with a valid, unused invite request. That part number does not appear to be valid on their main site. Do they not mention which OS it is?
Hi
From memory it was Debian but as you say you can't go back and check.
Cheers
Paul
sdjf
Tue May 29, 2012 4:09 pm
Cheers
Paul
Does that mean we cannot look around a few visits and use our activation code to buy after deciding what to do? I am not ordering until I can find out the total payment and shipping method, so we may have a stalemate here.
sdjf
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
grumpyoldgit
Tue May 29, 2012 4:18 pm
sdjf wrote:
Cheers
Paul
sdjf
From the large number of postings on here on this very subject, you can't just go in, faff about, come out and go in again as your code will then be deemed invalid. It is best not to even tread backwards on your browser to go to previous pages. The site is very unforgiving. The P&P is £4.95 or equivalent, world wide, if I recall. Once your code becomes invalid you will need to leave it a few hours to reset itself. If you are just buying the Pi, the total comes to about £30.50.
sdjf
Tue May 29, 2012 10:54 pm
This is taken from the RS FAQ they attached in response to my email. It seems we can browse the store as much as we want, and our activation codes are good until we place an order.
Here is what they say about this:
Q - My session timed out/crashed/disconnected/failed/I was unable to complete my purchase and
now my code is no longer being accepted. What can I do?
A - Please clear all cookies from your browser, exit and restart your session. Then try to place your order again after 1 hour. The basket should automatically empty allowing your code to
be re-used.
However, from all that I have read, I think I am bailing out from RS and going to wait to order from Newark.com once the backlog has dissipated. That will be much cheaper for me in the USA than getting from RS and also give me more ability to control the shipping date, since I cannot be sure there will be any way to receive a delivery this summer with the vague way things are working with advance ordering at both companies.
I called Newark and, once they understood my situation, they were very helpful.
jefferzbooboo
Thu May 31, 2012 9:13 am
I just received my Pi, used an SD card I had laying around and had to re install the image once to get it to work. I did it all in terminal on an Ubuntu 8.04 distro fallowing instructions I found in the Wiki, took me about 30-40 minutes to set up with the one screw up. The only ever time I've used terminal is to get Opera and that was many moons ago.
It's not as hard as people think to install the OS on the SD card.
