andrew700andrew
GPS ALTERNATIVE to Adafruit GPS Ultimate Breakout Board
Thu Dec 19, 2013 10:43 pm
I'm looking to connect a gps to my raspberry pi and beforeanyone says that i should just look at the Adafruit GPS Ultimate Breakout Board and the tutorial with it, i was searching amazon and i saw this :
http://www.amazon.co.uk/Generic-NEO6MV ... ps+module
It is half the price but when i look at the connections in the photo instead of the 3.3v connection that is in the adafruit gps, this one has a vcc one instead. I also don't know if this board uses a 3.3v or 5v communication. Btw. I am a complete novice at electronics hardware and have spent the last 2 hours googleing how to do this and about wiring pi's and have ended up confused about what to do next, so i was wondering if any of you more experienced and knowledgeable raspberry pi'ers would be able to tell if this follows the same method as the adafruit gps just by looking at it?
Thank you so much!
andrew
andrew700andrew
Re: GPS ALTERNATIVE to Adafruit GPS Ultimate Breakout Board
Fri Dec 20, 2013 9:52 am
Also, I've found out (by searching NEO6MV2) that the board is probably 3.3v to 5v compatible. HOWEVER, does this mean that I need to modify it to work on 3.3v or can I just plug it straight into my pi serial port?
technoducky
Sun Dec 22, 2013 11:59 pm
Yes this board will work with 3.3v logic, you should be able to connect this to the Pi in exactly the same was as the Adafruit module and have it work.
The Adafruit module also accepts multiple input voltages, the 3.3v pin is from the output of the regulator.
Dan
ame
Mon Dec 23, 2013 12:09 am
Buy this instead:
http://www.amazon.co.uk/GlobalSat-BU-35 ... B000PKX2KA
No wires to fiddle with. It has an enclosure. It's magnetic. Plug it into USB and it Just Works.
True, it's twice the price, but it's available more cheaply elsewhere.
Is there any reason you want a bare board?
Mon Dec 23, 2013 12:24 am
If I needed GPS on my RPi I'd be going with your £15 bare board.
Looks like it's a simple serial interface, so wire VCC to 3V3, GND to GND, TX on Pi GPIO to RX on board, RX on Pi to TX on board.Fiddle with the /boot/cmdline.txt by removing the /dev/ttyAMA0 config in there and you should be good to go.
andrew700andrew
Tue Dec 24, 2013 11:28 am
Thanks everyone!!
I'll be going with the cheaper one that you have to wire up because I'm planning on using the USB ports for other things and I don't want to use a hub.
mypifi
Sun Jan 05, 2014 2:00 pm
i got one of the blox ones used for rc planes etc off ebay for about a tenner wires fit as per adafruit one and works fine with myproject.
scruss
Sun Jan 05, 2014 6:00 pm
Another source of cheap USB GPS units is outdated versions of Microsoft Streets & Trips. These ship with a simple TTL Serial GPS (a Pharos PB010) connected to a Prolific serial→USB converter. Plugged into a Raspberry Pi, it creates a serial port spitting out NMEA sentences at 4800 baud. If you trawl the software clearance places, you can find these for £10-15.
One day, I'd like to try one of those small I²C GPS units meant for quadcopters with the Raspberry Pi.
Pronouns: he/him
RH314
Thu Jan 30, 2014 4:57 pm
Another interesting alternative is a 3.3V breadboard friendly $19 programmable GPS with 50MIPS + 490KByte Flash + 45KByte RAM for user program while running 10Hz GPS: http://bit.ly/1dBpits
Carl_Panek
Tue May 05, 2015 2:24 pm
Has anyone gotten a NAVATION GPS 168 to work on an RPI under raspbian?
scruss
Wed May 06, 2015 12:03 am
The GPS 168 was shipped with some versions of Streets & Trips, so it wouldn't surprise me if it worked like the Pharos. It probably appears as a serial port. What's the tail end of the output from dmesg after you plug it in?
Pronouns: he/him
Carl_Panek
Wed May 06, 2015 1:31 am
You are right about the source, and you put me on the right path by having me check dmesg. GPS 168 shows up at ttyACM0 and is now reading fine. A BIG THANK YOU.
