sneaky
Mail function is not working
Thu Dec 19, 2013 9:57 pm
Im new to raspberry pi.
I installed the raspian OS on it. I want to send emails from it using my gmail account. I want to send from the command line interface and from php scripts.
I followed this guide.
http://iqjar.com/jar/sending-emails-fro ... pberry-pi/
I did steps 1,2,3,4 from the link.
When I send an email using the code below using
echo "Test text" | mail -s "Test Mail" [email protected]
nothing happens, there is nothing printed on the screen, and I don't get the email.
On "revaliases", if I replace "mail.google" with "smtp.gmail", then I get back a message saying
send-mail: Cannot open mail.google.com:587
or
send-mail: Server didn't like our AUTH LOGIN (530 5.7.0 Must issue a STARTTLS command first. ml2sm3592928igb.10 - gsmtp)
Does anyone know how to fix this?
Here are the two files below:
ssmtp.conf
# Config file for sSMTP sendmail
# The person who gets all mail for userids < 1000
# Make this empty to disable rewriting.
# root=postmaster
# The place where the mail goes. The actual machine name is required no
# MX records are consulted. Commonly mailhosts are named mail.domain.com
# mailhub=mail
# Where will the mail seem to come from?
#rewriteDomain=
# The full hostname
hostname=raspberrypi
# Are users allowed to set their own From: address?
# YES - Allow the user to specify their own From: address
# NO - Use the system generated From: address
FromLineOverride=YES
[email protected]
mailhub=smtp.gmail.com:587
[email protected]
AuthPass=mypass
UseSTARTTLS=YES
revaliases
# sSMTP aliases
# Format:	local_account:outgoing_address:mailhub
# Example: root:[email protected]:mailhub.your.domain[:port]
# where [:port] is an optional port number that defaults to 25.
root:[email protected]:mail.google.com:587
fr0zen
Re: Mail function is not working
Sat Dec 21, 2013 9:56 pm
The email on my Pi works using the same command line code you pasted, so something must be up.
This is the only line I use in my revaliases file:
pi:[email protected]:smtp.gmail.com:587
Also did you chmod it like the article suggests:
chmod 774 /etc/ssmtp/ssmtp.conf
If this doesn't work it might be your ssmtp.conf file.
Sun Dec 22, 2013 8:53 pm
You need a MTA running.
sudo apt-get install postfix
that one is sane and easy to configure.
This is a doctor free zone.
crystalblade
Thu Dec 28, 2017 1:16 pm
Hi
Did you solve your problem?
Because i am following the same article and have the same problem as you did.
Let me know if you got it working and how you did it.
Thx
tpylkko
Thu Dec 28, 2017 1:55 pm
I believe gmail wont allow you to send mail unless you either 1) use one of Google's own mail clients (or other popular ones that are whitelisted) or 2) change the account settings so that you "allow unsafe programs" (or something to that end) from the options.
Thu Dec 28, 2017 2:16 pm
Following four year old instructions is not a good idea. Much has changed since then.
Thu Dec 28, 2017 2:48 pm
Hi
Thx
Necromancing an ancient thread.
Try this from 2017:
http://hacking.elboulangero.com/2017/07 ... gmail.html
Retired disgracefully.....
