sprinklekidd
HELP! I can hear sound but video wont play
Wed Dec 18, 2013 11:57 am
Today i purchased MPEG-2 and VC-1 licences for my pi, and have verified that they enabled. I can play wmv files now however i still cant play some avi files.(I can hear the sound but the video wont play)
Could someone please point out whats wrong with these files? should i convert them (i really don't want to do that) or should the pi be able to play these files. Any help is greatly appreciated. :D
the first file is:
  • General
    Complete name : G:\TV Seasons\The Smurfs\Season 1\Smurfs - 1x01 - the astro smurf.avi
    Format : AVI
    Format/Info : Audio Video Interleave
    File size : 168 MiB
    Duration : 22mn 19s
    Overall bit rate : 1 050 Kbps
    Writing library : VirtualDub build 13719/release
    Video
    Format : MPEG-4 Visual
    Codec ID : DIV3
    Codec ID/Hint : DivX 3 Low
    Duration : 22mn 19s
    Bit rate : 945 Kbps
    Width : 480 pixels
    Height : 360 pixels
    Display aspect ratio : 4:3
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.228
    Stream size : 151 MiB (90%)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Mode : Joint stereo
    Mode extension : Intensity Stereo + MS Stereo
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 22mn 19s
    Bit rate mode : Constant
    Bit rate : 96.0 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Stream size : 15.3 MiB (9%)
    Alignment : Split accross interleaves
    Interleave, duration : 42 ms (1.00 video frame)
    Interleave, preload duration : 500 ms
and the second file
  • General
    Complete name : G:\TV Seasons\Jackie Chan Adventures\Season 1\1x01- The Dark Hand.avi
    Format : AVI
    Format settings : rec
    File size : 364 MiB
    Duration : 19mn 27s
    Overall bit rate : 2 614 Kbps
    Video
    Codec ID : MP42
    Codec ID/Info : Microsoft MPEG-4 v2 (pre-standard)
    Codec ID/Hint : Microsoft
    Duration : 19mn 27s
    Bit rate : 1 198 Kbps
    Width : 544 pixels
    Height : 408 pixels
    Frame rate : 25.000 fps
    Bits/(Pixel*Frame) : 0.216
    Stream size : 167 MiB (46%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Duration : 19mn 27s
    Bit rate : 1 411.2 Kbps
    Bit depth : 16 bits
    Stream size : 196 MiB (54%)
    Alignment : Aligned on interleaves
    Interleave, duration : 2994 ms (74.84 video frames)
Re: HELP! I can hear sound but video wont play
Wed Dec 18, 2013 12:09 pm
I don't think those particular formats are supported- they are non-standard Microsoft specific ones, but Dom will have a better idea.
topguy
Wed Dec 18, 2013 1:10 pm
Which player are you using ?
dom
Wed Dec 18, 2013 2:07 pm
Yes, DivX 3 is not MPEG-4 compliant. You will need to transcode it.
I believe DivX 4 and later (and all XviD version) are MPEG-4 complaint and will play.
sprinklekidd
Thu Dec 19, 2013 12:33 am
Thanks for the reply. Im using Raspbmc, Ill have to convert them. *sigh*
Thu Dec 19, 2013 9:04 am
Green normally indicates that the UV channels are zero. Remember that they are normally measured -0.5 to +0.5, so 0 is in effect 128 (in 0p8 terms). So put 128 in to the YUV channels and see what happens.
sprinklekidd
Thu Dec 19, 2013 8:39 pm
jamesh could you recommend a freeware program to change the YUV channel? I cant seem to find anything :roll:
