Hello;
Looking for help with my wifi setup as well. Followed most of the instructions in this post but still can't get wifi adapter working. When i highlight the network icon in upper left of raspbian it says "Not Associated" and when i left click on the icon it indicates there are "no wireless interfaces found"
Here are a few screens:
/etc/network/interfaces shows the following:
source-directory /etc/network/interfaces.d
auto wlan0
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default int dhcp
supplicant.con shows:
update_config=1
network={
ssid="MY_Network ID""
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
psk="password"
auth_alg=OPEN
dmesg | grep usb shows:
[ 2.950099] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:4f:6e:ef
[ 3.045919] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 3.157237] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8179
[ 3.169393] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.181954] usb 1-1.4: Product: 802.11n NIC
[ 3.191364] usb 1-1.4: Manufacturer: Realtek
[ 3.445902] usb 1-1.2: new low-speed USB device number 5 using dwc_otg
[ 3.557793] usb 1-1.2: New USB device found, idVendor=05ac, idProduct=0256
[ 3.557806] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
lsmod shows:
Module Size Used by
cfg80211 399468 0
rfkill 16799 1 cfg80211
r8188eu 432632 0
bcm2835_gpiomem 3023 0
bcm2835_rng 1824 0
snd_bcm2835 19739 3
snd_pcm 75040 1 snd_bcm2835
snd_timer 18668 1 snd_pcm
evdev 10552 4
joydev 9427 0
snd 52620 9 snd_bcm2835,snd_timer,snd_pcm
uio_pdrv_genirq 2986 0
uio 8228 1 uio_pdrv_genirq
i2c_dev 6108 0
fuse 82598 3
ipv6 343492 28
ifconfig -a shows:
wlan0 Link encap:Ethernet HWaddr 40:a5:ef:0a:12:58
inet6 addr: fe80::96a6:1b8d:6b34:d94c/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
ifconfig shows:
wlan0 unassociated Nickname:"<WIFI@REALTEK>"
Mode:Auto Frequency=2.412 GHz Access Point: Not-Associated
Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
dhclient -v wlan0 shows:
Internet Systems Consortium DHCP Client 4.3.1
Copyright 2004-2014 Internet Systems Consortium.
All rights reserved.
For info, please visit
https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/40:a5:ef:0a:12:58
Sending on LPF/wlan0/40:a5:ef:0a:12:58
Sending on Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 4
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 17
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
iwlist wlan0 scan
Cell 05 - Address: DC:EF:09:91:A7:39
ESSID:"My_Network ID"
Protocol:IEEE 802.11bgn
Mode:Master
Frequency:2.462 GHz (Channel 11)
Encryption key:on
Bit Rates:144 Mb/s
Extra:rsn_ie=30140100000fac040100000fac040100000fac020c00
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
IE: Unknown: DD7F0050F204104A0001101044000102103B000103104700109CE1B15CBD8368523C2F541CC720563F1021000D4E4554474541522C20496E632E1023000552373030301024000552373030301042000233321054000800060050F20400011011000A4E696768746861776B52100800022008103C0001031049000600372A000120
Cell 06 - Address: B4:75:0E:66:57:B7
ESSID:"under_the_sea"
Mode:Master
Encryption key:on
Bit Rates:300 Mb/s
Extra:wpa_ie=dd160050f20101000050f20201000050f20201000050f202
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (1) : TKIP
Extra:rsn_ie=30140100000fac020100000fac040100000fac020000
Group Cipher : TKIP
Everything is as shown but I changed my wifi network name for public consumption. Please help
