DominusPi
SSH doesn't allow me to modify file
Tue Dec 03, 2013 9:04 pm
Hey guys,
First of all, I've already used SSH, and have it enabled on my pi.
Now the thing is, I'd like to modify a file (more precisely /etc/network/interfaces) from the computer but it doesn't let me, it says "permission denied"
For the record I'm using cyberduck on windows to use ssh.
Thanks in advance !
Cheers !
FTrevorGowen
Re: SSH doesn't allow me to modify file
Tue Dec 03, 2013 9:12 pm
DominusPi wrote:Hey guys,
Thanks in advance !
I'm guessing you're logged in as the "pi" user but not using the "sudo" command to prefix your edit command** (this assumes that "cyberduck" opens a ssh "terminal" session - when on windows I use PuTTY)
("man sudo" for more info.)
Trev.
** eg. "sudo nano /etc/network/interfaces"
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
DominusPi
Tue Dec 03, 2013 9:30 pm
So yeah, the problem was due to cyberduck, on which I do not know how to become the sudo (it's not a terminal, kind of a folder manager).
Tried Putty, worked just fine.
Thanks FTrevorGowen !
Cheers !
Tue Dec 03, 2013 10:06 pm
DominusPi wrote:So yeah, the problem was due to cyberduck, on which I do not know how to become the sudo (it's not a terminal, kind of a folder manager).
Use PuTTY to set a strong password for root (do not use 12345, root, raspberry, pi, root or password).
sudo passwd
[follow the prompts]
Then use root & your new strong root password in cyberduck.
Beware: using it as root doesn't pull any punches. You can a) overwrite every file b) remove every file.
This is a doctor free zone.
redhawk
Tue Dec 03, 2013 10:12 pm
Alternatively you could simply run: sudo su to grant you root access without the need to change the password.
Richard S.
Tue Dec 03, 2013 10:14 pm
redhawk wrote:Alternatively you could simply run: sudo su to grant you root access without the need to change the password.
Richard S.
Not from cyberduck he can't. Read the first half of this thread.
