dropkickguy
No HDMI Video signal on bootup
Sat Nov 30, 2013 11:00 pm
I am using and TV connected via HDMI cable to my Raspberry Pi. When I have my TV turned on and I turn on the Pi; I do get a video signal with no problems.
The problem is when I power on my Raspberry Pi and I forget to turn on my TV or forget to change to the corresponding HDMI input on my TV. I get no video. It may be my TV may not immediately notice the Pi's HDMI or may not do the negotiation. Has anyone else had this experience?
FTrevorGowen
Re: No HDMI Video signal on bootup
Sun Dec 01, 2013 5:55 pm
dropkickguy wrote:I am using and TV connected via HDMI cable to my Raspberry Pi. When I have my TV turned on and I turn on the Pi; I do get a video signal with no problems.
Depending upon your O.S. and the (default) settings in "config.txt" your Pi may be expecting a "hot-plug" signal from your TV. If this is not present (because the TV is "off" or not in "HDMI mode) during boot-up your Pi could be "falling back" to composite video (as to be expected).
Trev.
dropkickguy
Mon Dec 02, 2013 1:30 am
Trev - Thank you so much for the input. I am running Raspbian Wheezy. I do have the default settings, force hot plug etc. I went a purchased a new TV and tested the RPi before making changes to my settings and to my surprise the problem went away. Now, I can boot my RPi with my TV off and when I turn my TV on I have HDMI signal. I also tried booting up with my TV in an input other than RPi, and when I change the input to my RPi I have RPi HDMI signal.
I was using a 21" HD TV previously. I'm still curious as to why the problem was happening. I don't suggest everyone go out and purchase a new TV because of this issue though :3 I just wanted a bigger screen on which to play Emulation Station.
So to recap, my solution was purchasing a new TV and issue resolved.
Phill Rymer
Mon Dec 02, 2013 1:46 am
I get it all the time tv doesn't default to hdmi needs manually setting on my tv remote it has a source button I have to select hdmi to run pi
