In case you wondered about using a IPhone power supply on pi
Posted: Sun Nov 17, 2013 9:10 am
by Jozoguy39
I found it works using most USB to microUSB cables because the supply has 5v and 1a and I've tested It out
Re: In case you wondered about using a IPhone power supply o
Posted: Sun Nov 17, 2013 2:31 pm
by allfox
I'm using a Amazon Kindle charger which is 1.8A max. I'm not sure if it is always able to output that much or require some USB talk between the device, but Pi just working well so I ignore that.
Posted: Sun Nov 17, 2013 3:49 pm
by FTrevorGowen
Jozoguy39 wrote:I found it works using most USB to microUSB cables because the supply has 5v and 1a and I've tested It out
FWIW, you may be interested in these measurements: http://www.cpmspectrepi.webspace.virgin ... rger_A1399 (esp. when compared with those for the "clone" that follows)
Trev.
Posted: Sun Nov 17, 2013 5:29 pm
by tvjon
"FWIW, you may be interested in these measurements"
That's a very comprehensive set you have there!
I see your zip-drive has a UK plug. Both mine have an "infinity" type socket instead. I've actually used one of them as a 5v. supply on one of my bicycles, by connecting its input to a Shimano dynamo :)
Posted: Sun Nov 17, 2013 5:47 pm
by allfox
Trev.
This page is cool! I think it should be added to RPi wiki.
Posted: Sun Nov 17, 2013 6:05 pm
by FTrevorGowen
Trev.
Thank you. As it happens, those PSU's whose loading characteristics I've measured and I've used to power a Pi or two have been added to the wiki by me (if they weren't already there) with a reference link.
Trev.
