warranty and overclocking
Posted: Tue Nov 05, 2013 12:35 pm
by ric96
1) by how much can i overclock the pi and not loose the warranty??
2) by how much can i overclock the pi and still run it stably and not affect its life???
Re: warranty and overclocking
Posted: Tue Nov 05, 2013 12:40 pm
by allfox
1) Overclock won't cancel your warranty:
http://www.raspberrypi.org/archives/2008
2) Stability is differ from board to board. Read the article.
Posted: Tue Nov 05, 2013 2:31 pm
by ric96
Woha cool!!!!
But does this apply only to turbo mode or all modes from modest to turbo???
BTW i am using model b rev2 with hynx chip, wouldit be stable on arm= 800 and core= 300 and rest at default???
Thnx
Posted: Tue Nov 05, 2013 2:59 pm
by jamesh
ric96 wrote:
Woha cool!!!!
Thnx
You have no idea whether it will be stable unless you try it.
Posted: Tue Nov 05, 2013 3:21 pm
by DavidS
Overclocking will ONLY affect the warranty if:
You use both Force_Turbo=1 and Over_Voltage or if you use current_limit_overide, or if you set temp_limit above 85. As far as I know there is no other way to void the warranty by overclocking.
