emabellor
OpenMax JPEG - Raspberry Pi
Tue Oct 29, 2013 2:01 pm
Hello Everybody
I'm working in a Project where I use 2 JPEG cameras with a resolution of 640x480. I need to implement a motion detection algorithm, so I'm looking for the fastest way to convert a JPEG image in a YUV or RGB format.
Last week I heard about OpenMax. I built the examples in the folder /opt/vc/src/hello_pi, and I tested the example "hello_jpeg". I have no problems with lower resolution (320x240, JPEG-RGB conversion time: 10ms), but when I tested it with a 640x480 image, the time conversion is around 2 seconds.
Has somebody tried before this algorithm with high resolution images? I need to use OpenMax because software conversion needs a lot of time.
Thanks for your help.
Re: OpenMax JPEG - Raspberry Pi
Tue Oct 29, 2013 2:08 pm
Does that include saving the result to SD card? Or is that in memory conversion?
emabellor
Tue Oct 29, 2013 3:30 pm
jamesh wrote:Does that include saving the result to SD card? Or is that in memory conversion?
No, I send the image stream by http using mjpeg_streamer. Working on the code and reading the forum, I commented the following part in jpeg.c:
//  if ((done == 0) || (decoder->pOutputBufferHeader == NULL))
//  sleep(1);
Now It seems to work. To convert 640x480 images, it requires 10ms.
Tue Oct 29, 2013 4:30 pm
I have a feeling that the hello_jpeg code isn't as up to date as it needs to be - there are some odd bits of code in there.
jviyer
Sat Dec 07, 2013 8:48 pm
I have tried several files with hello_jpeg.bin, including a sample that was 320X240
In each case I get "did not receive executing stat -1" error.
The lowest resolution I tried was 320X240. for that I also get the addition line of output:
"No EOS event on image resizer 1"
any ideas what I could be doing wrong ?
On all the other hello_pi, I have built and executed and they all work fine except the "hello_jpeg.bin"
