prairietech
Can't Copy & Paste to Raspberry
Tue Oct 22, 2013 12:02 am
I am unable to copy and paste code from a web page on my Windows 7 computer to my Raspberry.
Accessing the Pi via VNC to a terminal window on the Pi.
I've tried the mouse copy / paste and also the keyboard copy / paste. Neither works.
Tried to paste text from the Raspberry to Notepad on the W7 computer and that doesn't work either.
What am I missing?
klricks
Re: Can't Copy & Paste to Raspberry
Tue Oct 22, 2013 1:58 am
I have not been able C&P as well. Both systems act independently as they probably should.
I have resorted to other options like:
- Bringing up the web browser on the RPi (using XRDP)
- Email to myself using a web based email client
- Save as text file in notepad and move the files through a network share.
- etc
Be careful with C&P from web pages. Sometimes they have hidden characters embedded which will generate errors in a script or config file. I once did a C&P from a web page and had to edit the file and manually delete all the white spaces and blank lines before the config file would work properly.
blachanc
Tue Oct 22, 2013 2:57 am
maybe this could work for you:
the way I do it:
copy whatever text into a text document opened in notepad++,
select the text to paste in notepad++
right click in a putty window.
http://www.putty.org
ben
Autism/Asperger syndrome: what is your score on this quiz?
http://www.raspberrypi.org/forums/viewtopic.php?f=62&t=70191
