Ivan.L wrote:When I was trying the ESC with arduino, I didn't do any initializations. And I don't think in needs one, because this ESC is used in only RC cars.
Most ESCs need some kind of initialisation - usually involving pushing the sticks to extremes, just so that the ESC knows what the Max and Min signals are for this particular Transmitter.
Most of the ones I own require you to switch on the ESC in the "zero" position, then they beep, then you need to push the stick to Max and back to zero again. Then they beep again, and after that, the ESC is calibrated and armed.
You will have to simulate this with software if your ESC is like the above. Some are adaptive and will learn on the fly.
