Hove
espeak has gone German [SOLVED]
Fri Oct 18, 2013 9:08 am
I'd have espeak working well in English (except running Python outside of IDLE but that's a different post).
Today, I used it to test some speakers with "Hello world", and it had a strange accent which sounded German, so I tried "Guten tag" which was perfectly pronounced. I haven't deliberately changed my locale to germany, but I have updated and upgraded my Raspian, and I think that updated espeak to support other languages.
Anyone got any suggestions how to get espeak to recognise it's in England and needs English pronunciation?
www.pistuffing.co.uk - Raspberry Pi and other stuffing!
Hove
Re: espeak has gone German [SOLVED]
Fri Oct 18, 2013 9:45 am
The voices used by espeak is stored in the directory /usr/lib/arm-linux-gnueabihf/espeak-data/voices/ and subdirectories.
Unless you specify a voice on the command line, it uses the "default" voice file. To change the default voice to sound Italian go to the above directory and type
sudo mv default default.de
sudo cp it default
Due to many variants of English voice styles, there is a selection in the en subdirectory. In this case, for a straight English voice type
sudo cp en/en default
This takes effect the next time you run espeak
