crystal13
WIFI chipset for Raspberry: RT5370 or RT8188?
Mon Oct 07, 2013 4:30 pm
Hi to all,
I'm looking for a USB wifi adapter for Raspberry.
I saw that there are two types of USB wifi adapter:
1) adapter based on chipset RT5370
2) adapter based on chipset RT8188 (e.g. Edimax or TP-LINK)
The 2) I read that is plug&play for RPi, so there is not problem.
The 1) I read that is difficult to install on RPi.
Because the 1) is cheapest of the 2), do you know if 1) can runs anyway on RPi installing what it need?
Thank you very much in advance.
Oakham
Re: WIFI chipset for Raspberry: RT5370 or RT8188?
Mon Oct 07, 2013 5:02 pm
With the latest Raspbian Wheezy the Ralink RT5370 works OK.
Though personally I have had more reliabilty from the Realtek RTL8188 in Linux
http://elinux.org/RPi_VerifiedPeriphera ... i_Adapters
Searching is easy, most questions have been asked before !
crystal13
Wed Oct 09, 2013 9:53 am
Ok thank you.
At this link:
http://elinux.org/RPi_USB_Wi-Fi_Adapters
is reported:
Note: A Wi-Fi adapter will probably need more power than the Raspberry Pi USB port can provide, especially if there is a large distance from the Wi-Fi adapter to the Wi-Fi Access Point, or it is transferring large amounts of data. Therefore, you may need to plug the Wi-Fi adapter into a powered USB hub.
So, is really needed of a power hub for these usb wifi adapter?
do you know how much current is provided by USB port of RPi and how can see how much current is absorbed by the usb wifi adpater?
thanks!
PaulCheffus
Wed Oct 09, 2013 2:55 pm
crystal13 wrote:Ok thank you.
At this link:
is reported:
thanks!
Hi
I have an Edimax EW7811UN (RT8188) plugged directly into my Pi (original version with the polyfuses on the USB) and it has been rock steady since I started using it. This Pi is powered by a Blackberry charger 700mA.
Cheers
Paul
Procrastination - The Thief of Time.
crystal13
Wed Oct 09, 2013 3:01 pm
Thank you Paul.
the polyfuse is present only on Raspberry Pi Rev1?
What can cause the absence of the polyfuse?
thank you very much.
SirLagz
Wed Oct 09, 2013 3:21 pm
I've only ever used RT5370s since I got my first Pi back when they were first released. Never had any issues installing / using them.
PaulCheffus
Wed Oct 09, 2013 4:31 pm
crystal13 wrote:Thank you Paul.
Hi
The polyfuse for the USB (not the main F3 polyfuse) was removed in the later versions (first replaced with a 0R resistor then completely removed).
Cheers
Paul
crystal13
Wed Oct 09, 2013 5:04 pm
Ok perfect.
@SirLagz: please, can you tell me where did you buy the adaptor with chipset RT5370? (I would like to know the brand).
Also via private message, if you want....
Thank you to all!
Gianfranco
SirLagz
Thu Oct 10, 2013 12:17 am
I just bought some generic ones off eBay
Though the Tenda W311M adapters use RT5370s too
