NOOBS Torrent problem?
Posted: Sun Sep 29, 2013 3:34 am
by AmbroseChapel
I just tried to get NOOBS via the torrent link and got an error message:
Requested download is not authorized for use with this tracker.
Not sure what's going on, because it appears to be downloading anyway.
The tracker is downloads.raspberrypi.org:6969 and I'm using Transmission 2.82 (14160) on OS X 10.6.8
Re: NOOBS Torrent problem?
Posted: Sun Sep 29, 2013 8:08 am
by rdb
We're aware of the issue and will hopefully have it fixed by end of day on Monday.
Did the torrent still download successfully?
Posted: Mon Sep 30, 2013 8:46 am
by AmbroseChapel
I downloaded a file which is 1,201,347,979 bytes and successfully unzips, so I'm going to say Yes.
Posted: Mon Sep 30, 2013 9:15 am
by rdb
Excellent. The torrents should now be fixed too.
Let me know if you have any further issues.
Posted: Mon Sep 30, 2013 12:27 pm
by pksato
I also have this not authorized issue.
btdownloadheadless  http://downloads.raspberrypi.org/NOOBS_latest.torrent
saving:         NOOBS_v1_3.zip (1145.7 M)
percent done:   0.0
time left:      connecting to peers
download to:    /tmp/t/NOOBS_v1_3.zip
download rate:  0.00 K/s
upload rate:    0.00 K/s
download total: 0.0 M
upload total:   0.0 M
ERROR: rejected by tracker - Requested download is not authorized for use with this tracker.
For all other torrents I get, ERROR: bad data from tracker -
And, or, on vuze, take very long time to download start.
For test propose, download of some debian image works fine. Is not problem with btdownload or my connection.
Posted: Mon Sep 30, 2013 4:19 pm
by crazyskeggy
I'm not the OP, but I still have this problem downloading NOOBS 1.3 using Transmission on Ubuntu 12.04 (Wubi)
Posted: Mon Sep 30, 2013 4:35 pm
by rdb
crazyskeggy wrote:I'm not the OP, but I still have this problem downloading NOOBS 1.3 using Transmission on Ubuntu 12.04 (Wubi)
We thought that we had fixed it but obviously it's still an issue - looking into it now.
Posted: Mon Sep 30, 2013 4:48 pm
by rdb
Okay, I've restarted the torrent tracker. Has that fixed this issue?
We can't replicate this on our end unfortunately.
Posted: Mon Sep 30, 2013 5:08 pm
by crazyskeggy
Unfortunately not - I don't know if this will make any difference, but I'm currently in South-west Greater London, and have around 1Mbps of speed according to speedtest.net (but Chrome only tells me that I get around 100KB/s when I'm downloading anything (I'm currently downloading NOOBS the old-fashioned way, which is probably killing my internet for everyone else)
Posted: Tue Oct 01, 2013 3:05 am
by AndrewS
I've just tested on my 60Mb/s cable internet connection using Transmission 2.51, and I get the same error too.
I tried all the torrents listed on the downloads page, and they all work fine (including NOOBS_lite) with the exception of NOOBS_v1_3.zip which displays the error "Requested download is not authorized for use with this tracker." - I'm not a regular torrent user though so I have no idea what that means ;) The file does still download completely though. And I also checked the sha1sums of all the downloaded files, and they all match the values displayed on http://www.raspberrypi.org/downloads
Posted: Tue Oct 01, 2013 6:24 pm
by pksato
I'm still with error to download from torrents, NOOBS_v1_3 have this error:
And others:
Using btdownload, the official torrent client.
If client is uTorrent, Vuze or other, after some long time/erros its use DHT to find and download torrent content. If some others have the files. On this mean time, direct download is more quick.
Posted: Tue Oct 01, 2013 7:55 pm
by samper.d
I am using bit torrent client Transmission.
I was successful with Raspbian image through torrent. Supper fast.
I was unsuccessful downloading NOOBS through Torrent. 2 hours to go through direct download :(
Cheers
Posted: Thu Oct 03, 2013 12:19 am
by AndrewS
Quick update to say that I've just re-tested, and it all seems fine again now :)
Posted: Thu Oct 03, 2013 8:55 am
by rdb
This should hopefully now be fixed (for good this time).
Please let me know if the issue reappears.
Posted: Wed Oct 30, 2013 1:35 pm
by yjack
I'm seeing a similar issue. When I started the torrent in transmission I got the error 'Tracker gave an error: Tracker gave HTTP response 503 (service unavailable)'. Shortly afterwards the download magically started though. So far it's been going OK, but it hasn't finished yet.
Posted: Wed Oct 30, 2013 5:18 pm
by billybangleballs
Tracker returned an error: Tracker gave HTTP response code 503 (Service Unavailable)
Oct 30 16:28:29 raspberrypi transmission-daemon[2068]: 2013-09-25-wheezy-raspbian.zip Starting IPv4 DHT announce (good, 168 nodes) (tr-dht.c:574)
Oct 30 16:30:51 raspberrypi transmission-daemon[2068]: 2013-09-25-wheezy-raspbian.zip Tracker error: "Tracker gave HTTP response code 503 (Service Unavailable)" (torrent.c:531)
Oct 30 16:30:51 raspberrypi transmission-daemon[2068]: 2013-09-25-wheezy-raspbian.zip Tracker gave HTTP response code 503 (Service Unavailable) (announcer.c:994)
Oct 30 16:30:51 raspberrypi transmission-daemon[2068]: 2013-09-25-wheezy-raspbian.zip Retrying announce in 7242 seconds. (announcer.c:1003)
The tracker has decided not to play, it doesn't prevent the download but clients are not finding errors because nothing is wrong.
Posted: Tue Jan 21, 2014 4:51 pm
by Stigern
Same issues here, stuck at "Connecting to peers"
The regular download is going really slow, at 300kb/s.
Posted: Mon Jun 24, 2019 3:13 pm
by pgousios
Using Transmission 2.94 (d8e60ee44f) I am able to join the torrent to download NOOBS_v3_1_1.zip and 2019-06-20-raspbian-buster-full.zip however there is an error returned:
Tracker returned error: Requested download is not authorized for use with this tracker.
this is on MacOS that I am running the tracker.
I had no issues on the 2019-04-08 releases.
Pete G
Posted: Thu Jun 27, 2019 5:54 pm
by pgousios
I am no longer getting the error, and saw a different thread that shows someone seemed to change something to fix it.
