fuffkin
What's the fastest you can boot a Raspberry Pi?
Tue Sep 24, 2013 8:15 am
This is giving a voice to an open question from a number of other threads that wandered off topic.
There is a class of application such as trailcams, security cams where a really, really fast boot is essential. A typical Raspbian from a typical SD Card will take 20-odd seconds.
How fast? - Ideally in the single seconds. But how low can it go?
Here is a video of about a 3 second boot, which is mighty impressive but others have had difficulty reproducing it.
http://www.youtube.com/watch?v=4Fjfqz6FxC8
Factors I know that affect boot speed are:
- SD Card speed (this is a bit of a black art)
- Combination of boot from USB drive and SD Card
- Optimise Drivers loaded etc
How low can we go???
PiGraham
Re: What's the fastest you can boot a Raspberry Pi?
Tue Sep 24, 2013 8:38 am
It depends what you need to boot to do what you need.
At the extreme end of things...
The RasPi 'Chess in assembler' project boots to a chess game in under a second, but it only does what it needs to display graphics, implement chess logic and read GPIO.
People have Midi working on baremetal
http://hackaday.com/2013/01/22/raspberr ... ng-system/
I'm not sure if it's practical to use the PiCam at that level.
Applications you mention may need a file system and networking which are challenging in assembler.
It may take a few seconds to stabilise auto exposure on the camera. So that may limit the start-up time. It should be possible to use a simple fast sensor to meter the exposure (DSLRs do that, for very fast wake and shoot operation <1s)
fuffkin
Tue Sep 24, 2013 9:18 am
PiGraham Good points there.
I think this thread can perform a couple of functions:
- Curate what people have already achieved
- Techniques and what practically you can get
- Pointers as to where the start / look
For example, if I know that I can achieve sub-1s, BUT the only way I can get there is in assembler AND you can still use a camera, then I can then judge whether to take the plunge.
Technically, as you suggest most applications will probably need some form of file system and a lot of applications would require the camera.
shuckle
Tue Sep 24, 2013 9:56 am
My record with Rasbian without X is about 18 secs.
I am very interested to hear how you can get faster than that.
AndrewS
Tue Sep 24, 2013 10:04 am
NOOBS is a really good example of "how fast" you can boot the Pi - the "Recovery Menu" is actually a QT application running on top of a buildroot Linux OS, launched from an initrd 8-) (no assembler involved)
mikerr
Tue Sep 24, 2013 10:05 am
fuffkin wrote:Here is a video of about a 3 second boot, which is mighty impressive but others have had difficulty reproducing it.
I reproduced it easily - he does provide images:
https://github.com/gamaral/rpi-buildroot/downloads
E.g. download marshmallow-sdcard.img.xz (game)
or sdcard.img.xz (linux prompt)
.xz is just a .zip file - so uncompress with 7zip or something
then use win32 disk imager as normal to put on a SD card.
Note if using sdcard.img then the login is "root"" not pi !
