SSL ERROR
Posted: Mon Sep 23, 2013 2:08 pm
by LolAsdOmgWtfAfk
Hi, i would to buy a raspberry, but when i start the checkout, the browser warn me that the SSL certificate is expired.
You attempted to reach raspberrypi.rsdelivers.com, but the server presented an expired certificate. No information is available to indicate whether that certificate has been compromised since its expiration. This means Chromium cannot guarantee that you are communicating with raspberrypi.rsdelivers.com and not an attacker. Your computer's clock is currently set to monday 23 september 2013 16:03:47. Does that look right? If not, you should correct the error and refresh this page.
Can you tell me if i can use the checkout anyway?
Thank you so much.
Re: SSL ERROR
Posted: Mon Sep 23, 2013 2:11 pm
by texy
there is no point asking here - the foundation isn't selling you the raspberrypi, RS are.
You should contact RS directly.
Thanks,
Texy
Re: SSL ERROR
Posted: Mon Sep 23, 2013 2:14 pm
by LolAsdOmgWtfAfk
texy wrote:Hi,
Thanks,
Texy
Yes i know, you're right if you say i am posting in the wrong section (i see just now that this section refers the software store), but simply i'm only asking if someone has the same problem in the community.
