Al_Vertigo
camera board uv4l driver
Thu Sep 19, 2013 10:48 am
Hi all
I'm having problems with uv4l driver installation. I'm following the instructions shown here:
http://www.linux-projects.org/modules/s ... e&artid=14
Everything seems fine until "apt-get install" command, then packages can't be found.
Here is my sources.list file:
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
deb http://www.linux-projects.org/listing/uv4l_repo/raspbian/ wheezy main
And here is my console logs:
pi@raspberrypi ~ $ wget http://www.linux-projects.org/listing/uv4l_repo/lrkey.asc && sudo apt-key add ./lrkey.asc
--2013-09-19 12:19:24--  http://www.linux-projects.org/listing/uv4l_repo/lrkey.asc
Resolving www.linux-projects.org (www.linux-projects.org)... 62.149.140.25
Connecting to www.linux-projects.org (www.linux-projects.org)|62.149.140.25|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1337 (1.3K) [application/pgp-signature]
Saving to: `lrkey.asc'
100%[======================================>] 1,337       --.-K/s   in 0s
2013-09-19 12:19:25 (14.5 MB/s) - `lrkey.asc' saved [1337/1337]
OK
pi@raspberrypi ~ $ ls
Desktop  foto01.jpg  lrkey.asc  ocr_pi.png  python_games
pi@raspberrypi ~ $ sudo apt-get update
Hit http://www.linux-projects.org wheezy Release.gpg
Hit http://mirrordirector.raspbian.org wheezy Release.gpg
Hit http://archive.raspberrypi.org wheezy Release.gpg
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://www.linux-projects.org wheezy/main armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://www.linux-projects.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Reading package lists... Done
pi@raspberrypi ~ $ sudo apt-get install uv4l uv4l-raspicam
Building dependency tree
E: Unable to locate package uv4l
E: Unable to locate package uv4l-raspicam
pi@raspberrypi ~ $
Somebody can help me?
Thank you in advance
Best regards
topguy
Re: camera board uv4l driver
Thu Sep 19, 2013 2:10 pm
What do you get from:
sudo apt-cache search uv4l
Al_Vertigo
Fri Sep 20, 2013 11:25 am
No output is shown when execute this command.
thanks for reply
topguy
Sun Sep 22, 2013 2:11 am
I cant see anything wrong with your repo-setup, but still it seems that apt har not picked up on the new uv4l packages.
You can download them manually from http://www.linux-projects.org/listing/u ... ol/main/u/ and install them with:
dpkg -i filename.deb
but that is not the preferred method.
Al_Vertigo
Sun Sep 22, 2013 5:55 pm
Thank you Topguy, i'll try.
I'm accesing my raspi by ssh, could this be the problem?
topguy
Sun Sep 22, 2013 9:18 pm
Al_Vertigo wrote: I'm accesing my raspi by ssh, could this be the problem?
No, that should not have any effect. I update most of my Linux computers remotely over ssh.
ObiWahn
Tue Feb 11, 2014 10:05 pm
I've tried the same, but it still seems not to be working as described (using apt-get)
I managed to download using the given URL, but got his error when unpacking:
pi@pi-1 /tmp $ ls
MathLink uv4l_1.9_armhf.deb uv4l-raspicam-extras_1.0_armhf.deb
ssh-9lUWppV5uweG uv4l-raspicam_1.9.5_armhf.deb wpa_ctrl_1825-1
pi@pi-1 /tmp $ sudo dpkg -i uv4l_1.9_armhf.deb
Selecting previously unselected package uv4l.
(Reading database ... 70577 files and directories currently installed.)
Unpacking uv4l (from uv4l_1.9_armhf.deb) ...
Setting up uv4l (1.9) ...
Processing triggers for man-db ...
pi@pi-1 /tmp $ sudo dpkg -i uv4l-raspicam_1.9.5_armhf.deb
Selecting previously unselected package uv4l-raspicam.
(Reading database ... 70587 files and directories currently installed.)
Unpacking uv4l-raspicam (from uv4l-raspicam_1.9.5_armhf.deb) ...
Setting up uv4l-raspicam (1.9.5) ...
pi@pi-1 /tmp $ sudo dpkg -i uv4l-raspicam-extras_1.0_armhf.deb
Selecting previously unselected package uv4l-raspicam-extras.
(Reading database ... 70591 files and directories currently installed.)
Unpacking uv4l-raspicam-extras (from uv4l-raspicam-extras_1.0_armhf.deb) ...
Setting up uv4l-raspicam-extras (1.0) ...
update-rc.d: using dependency based boot sequencing
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match uv4l_raspicam.sh Default-Start values (S)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match uv4l_raspicam.sh Default-Stop values (none)
insserv: warning: script 'mathkernel' missing LSB tags and overrides
What to do now?
brian92127
Sun Jul 27, 2014 3:27 pm
I'm having exactly the same problem: Unable to locate package uv4l.
Since the last update to this string was in February, did you find a solution? Can you post it for everyone else to see?
Thanks!
gentro
Sun Oct 19, 2014 1:19 am
You have to configure apt-get to read from the linux-projects repo before you apt-get uv4l.
Full instructions here:
craven
Fri Aug 28, 2015 7:59 am
i think i found a solution for your problem.i also experienced same problem but if you follow these commands you can install without getting any errors
http://teycode.com/blog/raspberry-uv4l-opencv/
saharmohamedali
Sat Aug 29, 2015 11:41 am
[img]http://imgupp.com/img/1434586608.j ... 86608.html
thebeachtoday
Sat Aug 12, 2017 4:55 pm
Make sure you issue a sudo apt-get update after updating the sources.list and before installing the packages
