MartinLenord
Re: Raspberry Pi ASCII Art
Sat May 05, 2012 12:03 pm
Hi Folks,
I was lucky enough yesterday to receive my raspberry pi yesterday and set about setting it up and customising it a little.
Whilst doing that I decided to make some pretty ascii art for the login screen
It took some time to get the colours right, but I didn't think it was too bad for a first attempt
If you want to use it, you can download it here https://www.dropbox.com/s/7yrfpllwmx7ozfd/issue.txt
then just save it as /etc/issue to make it show up when logging in
If anyone else has made anything, I'd be interested to see what other people come up with
Martin
stevepdp
Sat May 05, 2012 12:30 pm
This is pretty cool, thanks.
For anybody curious as to how the colour codes work, they've been fairly well documented here.
b3n
Wed May 16, 2012 12:57 am
Came up with this
  (  : '~' :  ) Raspberry Pi
Script to output in colour
#!/bin/bash
echo "$(tput setaf 2)
  '. \ ' ' / .'$(tput setaf 1)
  (  : '~' :  ) $(tput sgr0)Raspberry Pi$(tput setaf 1)
$(tput sgr0)"
jezmck
Tue May 29, 2012 10:48 pm
The message isn't showing up for me.
Using debian.
On other machines I've edited /etc/motd.tail so I tried that here, but to no avail.
Any ideas?
ToyleY
Tue May 29, 2012 10:56 pm
Raspi (88)
jezmck
Wed May 30, 2012 7:09 am
Nvm, it works after a reboot.
Super-Nathan
Wed Jun 27, 2012 2:16 am
in debian:
/etc/motd.tail edits /var/run/motd on boot
/etc/motd is symlinked to /var/run/motd
/etc/motd is read by login and displayed
echo "Something Useful" > /dev/null
extravagoose
Wed Jun 27, 2012 7:40 am
b3n wrote:Came up with this
I've been able to incorporate this alongside an Arch Linux | ARM ASCII too... I will of course say credit to the respective authors of each mind - I'm useless creatively speaking. :P But this is how it appears on my terminal:
But If its any help to anyone, feel free to download the motd file from this page:
http://sjjones85.servebeer.com/files.html
RPi 1: Hostname: Gimli, 500Gb USB HDD, ArchLinux | ARM.
Main Use: Bit of everything - but mainly web server, Network Storage and C programming.
RPi 2: Hostname tba, awaiting delivery.
piksel
Sat Jun 30, 2012 12:19 pm
I made my own remix and an install script: https://gist.github.com/piksel/3023588
Update: Fixed url. Dont know why it stopped working without prefixing...
Igneosaur
Sat Aug 11, 2012 11:51 am
Sorry, I think I'm being stupid. I'm putting this directly into /etc/motd :
$(tput setaf 2)
       .~ .~~~..~.    $(tput sgr0)                   _                          _ $(tput setaf 1)
      : .~.'~'.~. :   $(tput sgr0)   ___ ___ ___ ___| |_ ___ ___ ___ _ _    ___|_|$(tput setaf 1)
     ~ (   ) (   ) ~  $(tput sgr0)  |  _| .'|_ -| . | . | -_|  _|  _| | |  | . | |$(tput setaf 1)
    ( : '~'.~.'~' : ) $(tput sgr0)  |_| |__,|___|  _|___|___|_| |_| |_  |  |  _|_|$(tput setaf 1)
     ~ .~ (   ) ~. ~  $(tput sgr0)              |_|                 |___|  |_|    $(tput setaf 1)
$(tput sgr0)
^Looks messed up here but you get the point...
But that's exactly what I'm getting straight out, no colours. I also tried putting it in quotes and after an 'echo' but still the same thing. It's not interpreting it, it's just being dumped out literally.
Naps62
Sun Aug 19, 2012 4:07 am
@Igneosaur
you have to paste the gist code in a different file, and run it as a script (with sudo). it will update the motd file itself
rilski
Sun Aug 19, 2012 5:16 am
Looks good!
Should be a included into something like an SSH/FTP or Telnet welcome message! lol :)
voltagex
Thu Dec 20, 2012 10:01 pm
update-motd anyone? Anyone?
http://man.he.net/man5/update-motd
ichi1984
Wed Jan 09, 2013 7:22 am
Hey guys, I've got my art all hammered out. When I run it in terminal as sudo sh /etc/issue it shows properly in terminal. Upon restart though, I see the regular grey text as with the color code mixed in. I'm a super noob to unix systems and this is as far as I could get myself :/
askschwa
Sat Jan 19, 2013 7:26 pm
piksel wrote:I made my own remix and an install script: https://gist.github.com/gists/3023588
I want to use your install script, but the link is not working anymore.
tgwaste
Sat Feb 09, 2013 6:16 pm
Looks great. Thanks guys!
minkowski
Mon Feb 11, 2013 3:40 pm
@tgwaste what's the code your using for the extra info? i like that mix of art and information.
thanks!
tgwaste
Mon Feb 11, 2013 7:24 pm
hello mink, here is a link to my welcome.sh which has everything you need.
http://dl.dropbox.com/u/61083309/www/content/welcome.sh
minkowski
Mon Feb 11, 2013 9:26 pm
thanks!
borsitsb
Fri Mar 15, 2013 11:58 am
@tgwaste: How can I run your shell script as message of the day in SSH?
Fol
Fri Mar 15, 2013 4:00 pm
@borsitsb : cron could do the job I think.
crontab -e
Then just add a new command, it can look like that for example, if you want to update your welcome message every hour :
(maybe cron and crontab are not strictly the same thing, I'm not sure about that)
* 1  * * * welcome.sh >> /etc/motd
When it is launched manually, all works well. However, done by cron, the text is there but all colors are missing... :?
Does someone has any idea about what is wrong ?
tgwaste
Fri Mar 15, 2013 6:59 pm
welcome.sh is a script. motd is not. welcome uses the command tput to set the colors but motd wont be able to do that, you will have to do colors probably like: ^[[1;XXm which is kind of a pain.
borsitsb
Fri Mar 15, 2013 10:11 pm
I renamed 'welcome.sh' to '01-welcome', then I moved it to '/etc/update-motd.d' folder and I waited for 10 minutes and nothing happened. What should I set?
Fol
Mon Mar 18, 2013 4:14 pm
@borsitsb : I can't really help you about this, I am not using update-motd. If I remember well, it is depreciated. I'm just using a cron job on the root account (a bit dirty maybe) and it does the trick.
I managed to update my /etc/motd with colors, using the awful color codes :
It is actually a mix between two codes given above.
#!/bin/sh
ip=`ip addr show scope global | grep inet | cut -d' ' -f6 | cut -d/ -f1`
up=`uptime | awk -F"up " '{print $2}' | awk -F"," '{print $1}'`
used=`df -h | grep 'dev/root' | awk '{print $3}'`
avail=`df -h | grep 'dev/root' | awk '{print $4}'`
echo "\033[0;32m
   '. \ ' ' / .'\033[0;31m
    .~ .~~~..~.    \033[0;37m                   _                          _ \033[0;31m
   : .~.'~'.~. :   \033[0;37m   ___ ___ ___ ___| |_ ___ ___ ___ _ _    ___|_|\033[0;31m
  ~ (   ) (   ) ~  \033[0;37m  |  _| .'|_ -| . | . | -_|  _|  _| | |  | . | |\033[0;31m
 ( : '~'.~.'~' : ) \033[0;37m  |_| |__,|___|  _|___|___|_| |_| |_  |  |  _|_|\033[0;31m
  ~ .~ (   ) ~. ~  \033[0;37m              |_|                 |___|  |_|    \033[0;31m
    \033[0;34m`hostname -f`
    \033[1;30m$ip
    \033[1;34mUsed | Free
    $used | $avail
    \033[1;30mUp. : $up
    \033[0;30m" > $1
And in crontab :
0 1  * * * /path/to/updateMotd.sh /etc/motd
Edited crontab command, it was totally wrong...
borsitsb
Mon Mar 18, 2013 10:00 pm
Thank you! It is working now :) . I'm beginner in Linux unfortunately, so I didn't know I should grant execute permission for that file either, but I managed it.
