Blars
Re: Power regulation
Mon Aug 29, 2011 3:46 pm
Is the on-board power regulator(s) going to be switching or not? Looking at the pictures of the alpha version, I see what appears to be a 3-pin regulator and don't see an inductor, so I'm guessing non-switching.
So for low-power applications we will need an external switching regulator, and I'd worry about heat disipation if the board was given 20v.
ShiftPlusOne
Mon Aug 29, 2011 3:49 pm
I think that's just an alpha board thing. They have mentioned they'll be using an SMPS to step the voltage down to 5V and then another to 3.3V.
liz
Mon Aug 29, 2011 3:59 pm
ShiftPlusOne is right - what you see on the alpha board isn't necessarily a good indicator of what you'll see in the final version!
