gmc
[SOLVED] Colors in putty
Sat Aug 17, 2013 9:02 pm
Not sure if this is a setting on the R-Pi, when I putty into say my opensuse server I get the directories, scripts etc in different colors.
When I ssh to the pi its all in black and white? Any idea what th problem could be?
FTrevorGowen
Re: Colors in putty
Sat Aug 17, 2013 9:18 pm
It may be your PuTTY settings. In PuTTY's "Windows --> Colours" settings I've "ticked" all three "General options for colour usage" and get coloured text from the Pi.
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
MrBunsy
Re: Colors in putty
Sat Aug 17, 2013 9:22 pm
Settings for this are in the .bashrc file. I can't find any particularly good links to give you, but the Arch wiki may help: https://wiki.archlinux.org/index.php/Color_Bash_Prompt
FTrevorGowen
Re: Colors in putty
Sat Aug 17, 2013 9:38 pm
I should have asked: What OS are you running? Do you get coloured directorys etc. when you're logged directly on to the Pi and using a monitor? If not, then MrBunsy is "on the right track". For me Raspbian Wheezy normally gives coloured text in "ls -laF" listings etc. without me having to add or change anything in .bashrc (or similar) ie. it appears to be "the default option".
Trev.
ddxfish
Contact: Website AOL
Re: Colors in putty
Sun Aug 18, 2013 1:45 am
edit ~/.bashrc (or .bash_profile if you are using interactive logon)
add these to spice up the color a bit, it is your linux install, not putty most likely.
ls to be listed in color
alias ls='ls -al --color'
your user prompt in color
export PS1="\[\e]0;\[email protected]\h: \w\a\]${debian_chroot:+($debian_chroot)}\[\033[0;31m\]\[email protected]\h\[\033[00m\] \[\033[01;34m\]\w \$\[\033[00m\]"
My Pi Guides: http://www.etcwiki.org/wiki/Category:Raspberry_Pi
My AIM screen name: ddxfish
Always happy to chat about the Pi!
gmc
Re: Colors in putty
Sun Aug 18, 2013 6:46 am
Thanks for all the tips.
Its odd, but its just started working. I did change the timezone and hosrname and there were a few reboots so am not sure if that fixed it, but I have all the colors back.
Putty'ing from Win8 to wheezy (the latest version, all patches installed)
Update: Ahhh...figured it out. I was running in sudo mode
sudo -s
Everything is in b&w when I do this, doing a exit and returning to the pi user everything is back to normal. I've copied over the relevant color setting from pi's .bashrc to root's .bashrc and its fixed it.
