Getting to the terminal in RaspBMC
Posted: Fri Aug 16, 2013 9:05 pm
by pfi
A real Noob question - how do I access the terminal when I'm using RaspBMC?
Is there a terminal window?
Help!
Re: Getting to the terminal in RaspBMC
Posted: Fri Aug 16, 2013 10:59 pm
by topguy
There is probably not one that you can access with your connected keyboard and display. But you *can* log in via SSH over the network from another computer.
More info at the official site:
http://www.raspbmc.com/wiki/user/using-ssh/
Posted: Sat Aug 17, 2013 7:53 am
by pfi
topguy wrote:There is probably not one that you can access with your connected keyboard and display. But you *can* log in via SSH over the network from another computer.
Thanks TopGuy.
The problem that I want to solve is a network failure. I have no wifi and cannot use an ethernet cable. So SSH is not a solution for now.
Posted: Sat Aug 17, 2013 3:45 pm
by Tylegoguy
Press ESC during boot.
Edit: Does not work on OpenElec
Posted: Sat Aug 17, 2013 6:34 pm
by Dilligaf
With Raspbmc running exit xbmc from the shutdown menu (choose Exit, not shutdown) at the blue screen press Esc you will be greeted with a login prompt, default user/pass is pi/raspberry
Posted: Sun Aug 18, 2013 4:26 pm
by mrpi64
There is (or maybe WAS) a glitch that, when you logged off, you were taken to the terminal. That was some time ago, they have probably fixed it though...
Posted: Thu Aug 22, 2013 9:23 am
by pfi
Thanks everyone for your help.
I do think the RaspBMC developers could make terminal access more obvious.
