LesGirauds
Need a case and HDMI cable
Tue Aug 13, 2013 3:02 pm
Hello all,
I've been enjoying my Pi for many months now, used as a media centre running XBMC. I've now got it to a more-or-less stable state and want to mount it on the back of my TV (the VESA mount is already is use). I currently have the standard plastic Pi case (which is not the best tbh, imo)
Can anyone recommend a method of mounting the Pi, or a case designed for that purpose?
Other issue is the HDMI cable. The one I have is a fairly robust thing and being heavier weight than the Pi itself means I have to be careful how I put things together. It could easily flick the Pi across the room when I move the TV!! ;) So, is a lighter, more flexible cable available? I've not seen one personally but I thought it worth asking. The ideal cable would be very short, maybe 15 or 20cm.
Davespice
Contact: Twitter
Re: Need a case and HDMI cable
Tue Aug 13, 2013 4:15 pm
RaTTuS
Tue Aug 13, 2013 4:17 pm
you can probably use ^ that and mount it though the wall mount at the same time.
Covfefe
Speedwell68
Tue Aug 13, 2013 11:39 pm
The shortest HDMI lead I can find is 0.5m (20").
LesGirauds
Wed Aug 14, 2013 6:13 am
RaTTuS wrote:you can probably use ^ that and mount it though the wall mount at the same time.
I'm not sure what you mean by "mount it th(r)ough". Looking at the mounting arm I have, I don't think I could use it and that Pi case on the same VESA mount.
LesGirauds
Wed Aug 14, 2013 6:14 am
Speedwell68 wrote:The shortest HDMI lead I can find is 0.5m (20").
Same here. And pretty much all the same thickness. I was hoping for something shorter and more flexible. I'm now wondering if I can build my own??
LemmeFatale
Wed Aug 14, 2013 7:38 am
Cable-wise, would Pimoroni's fine "Noodles" be suitable?
They're flat HDMI (and Micro USB) cables. My experience with these sorts of things from elsewhere is that they're lighter and a bit more flexible than regular cables
EDIT: Bah, I just looked, and they're a bit longer than you're looking for. Sorry!
Classic - Raspberry Pi Model B (512MB) with Motorola Atrix Lapdock
Lemcon-One - Raspberry Pi Model B (256MB) PiMAME TV-Box
LesGirauds
Wed Aug 14, 2013 3:26 pm
Thanks LF. I emailed Pimoroni and they might be able to source a 30cm version. Fingers crossed!
plugwash
Wed Aug 14, 2013 3:39 pm
I wonder if you could use a plate of some sheet material between the vesa mounting holes on the TV and the bracket that supports the TV. Then attach your case to that sheet material.
LesGirauds
Thu Aug 15, 2013 7:25 am
That's a possibility plugwash. I'll give that some thought.
rurwin
Thu Aug 15, 2013 7:31 am
You could put a P-clip on the sheet as strain-relief for the HDMI cable.
