omega1
Micro USB power lead to open wires?
Fri Aug 09, 2013 2:51 pm
Hi all,
Does anyone know of a micro USB to 'open wires' cable that I can buy?
OR
Where can you buy a micro USB connector?
OR
Can I power my Pi (without soldering) via any other connector/port on the board (maybe GPIO)?
Thanks in advance.
Get your Pi from here! http://bit.ly/18blVup
RaTTuS
Contact: Twitter YouTube
Re: Micro USB power lead to open wires?
Fri Aug 09, 2013 3:00 pm
you can power via the GPIO
but you do bypass the fuse
or even from the nornal USB
Covfefe
omega1
Fri Aug 09, 2013 3:08 pm
Hi, thanks, waht are the GPIO connectors?
Is it 2 & 6 or 4 & 6?
exartemarte
Fri Aug 09, 2013 3:14 pm
I think I would just cut a micro-usb cable in half rather than spend time searching for one. Even if you find a source I doubt if you'd save any money by the time you'd paid the postage and packing.
Yes, you can power the Pi via the 0v and 5v pins in the GPIO connector - with 5v, obviously - but don't get it the wrong way round or confuse the +5v and +3.3v pins - there is no protection!
Since you ask the question I'm guessing you may be new to all this. I would steer clear of direct connection to the GPIO connector, and home-made cables too for that matter, unless you are sure of what you're doing.
omega1
Fri Aug 09, 2013 3:18 pm
There are two pins marked as +5V (pin 2 and pin 4), what (if any) is the difference?
RaTTuS
Fri Aug 09, 2013 3:22 pm
http://elinux.org/RPi_Low-level_periphe ... .28GPIO.29
DO NOT short +3V and +5V or you will get bye bye pi
Covfefe
omega1
Fri Aug 09, 2013 3:25 pm
Are pins 2 and 4 the same then? Both +5V?
RaTTuS
Fri Aug 09, 2013 3:37 pm
yes
Covfefe
omega1
Fri Aug 09, 2013 4:58 pm
bbmonster
Fri Aug 09, 2013 5:08 pm
If you go cutting a micro usb cable route, i would buy a few from different vendors off ebay. You can usually get them really cheap. The reason for getting a few is beacause as mentioned in other post not all cables are equally made. Some might have wires too thin or connected crappily to the connector that the cable cannot supply enough current.
Hope that helps.
omega1
Sat Aug 17, 2013 12:45 pm
You were right, I went down the cut the cable route and only ordered the cheapest going. The cables are so thin I'm surprised it even works!
As you said, I'll but a few different ones...
redhawk
Sat Aug 17, 2013 12:58 pm
Poundland and the 99p store sell USB cables usually advertised as Blackberry data cable or USB mobile phone charger adapter.
Just be aware these cables are usually of poor quality and could cause power losses unless cut near to the connector end or you solder thicker wires directly to the connector.
Richard S.
mad-hatter
Sat Aug 17, 2013 3:07 pm
Make your own (thick wires) cable.
http://uk.cellphoneshop.net/microusb.html
Regards
omega1
Sat Aug 17, 2013 3:25 pm
interesting, thanks!
I've ordered a couple to give the ma try, that was what I was looking for!
