FFAMax
Unable to handle kernel paging request - Broken board?
Wed Aug 07, 2013 6:39 am
Hello!
I check bulk of boards and detect one wich does not booting up.
Others working well.
What i can do with board, or i must return it to Farnell?
All time a see problem with address 0xa0000af
FFAMax
Re: Unable to handle kernel paging request - Broken board?
Wed Aug 07, 2013 7:42 am
I found some information.
With this settings board workin (boot up well, but perfarmance not tested):
core_freq=500
sdram_freq=550
over_voltage=6
start_x=1
gpu_mem=128
but if increase sdram_freq from 550 to 600 then board does not boot up.
If i comment this string
#force_turbo=1
then problem with address 0xa0000af.
if
force_turbo=1
then problem with address 0x0.
So it only turn off dynamic speed up and show that problem at speed sdram between 550-600.
Main question - this is normal for board or i must run RMA procedure?
RaTTuS
Contact: Twitter YouTube
Wed Aug 07, 2013 8:04 am
FFAMax wrote:...
core_freq=500
sdram_freq=550
over_voltage=6
start_x=1
gpu_mem=128
Defaults are
IIRC
arm_freq = 700
core_freq = 250
sdram_freq = 400
so if the defaults work and not when over clocking then you cannot realisticly expect a RMA
most will overclock - some will not
Covfefe
