Re: Boblight possible?
here you go:
http://vzoltan.com/stasiko/omxplayer-image.img.tar.gz
there is an 8gb dd image of my card, login is pi/raspberry, boblightd is installed config is in /etc/boblight.conf, the modified omxplayer is in /usr/local/src/omxplayer (WARNING: /usr/bin/omxplyer is a standard one)... so start it like ./usr/local/src/omxplayer/omxplayer. You can compile by calling make in /usr/local/src/omxplayer.
Stasik0 wrote:here you go:
thx for uploadin!
(just started to downloading)
well, it doesnt work for me:(Stasik0 wrote:here you go:
it connects to boblight but the led just wont change color...
pi@raspberrypi ~ $ sudo boblightd
(InitLog) start of log /root/.boblight/boblightd.log
(PrintFlags) starting boblightd
(CConfig::LoadConfigFromFile) opening /etc/boblight.conf
(CConfig::CheckConfig) checking config lines
(CConfig::CheckConfig) config lines valid
(CConfig::BuildConfig) building config
(CConfig::BuildConfig) built config successfully
(main) starting devices
(CClientsHandler::Process) opening listening socket on *:19333
(CDevice::Process) ambilight: starting with output "sudo python /home/pi/popen.py"
(CDevice::Process) ambilight: setting up
(CDevice::Process) ambilight: setup succeeded
(CClientsHandler::Process) 127.0.0.1:57699 connected
(CClientsHandler::ParseMessage) 127.0.0.1:57699 said hello
(CClientsHandler::ParseSet) 127.0.0.1:57699 priority set to 128
pi@raspberrypi ~ $ sudo boblight-constant FF0000
Connecting to boblightd
Connection to boblightd opened
pi@raspberrypi ~ $ cat popen.py
[/code]
import sys
spidev = file('/dev/spidev0.0', "wb")
gamma = bytearray(256)
for i in range(256):
gamma[i] = int(pow(float(i) / 255.0, 2.5) * 255.0 )
def popen():
while True:
eingabe = sys.stdin.readline()
if len(eingabe)>0:
eingabelist = eingabe.split()
ausgabe = bytearray(len(eingabelist))
for i in range(len(ausgabe)):
ausgabe[i] = gamma[int(round(float(eingabelist[i])*255))]
spidev.write(ausgabe)
spidev.flush()
popen()
it seems a problem with the boblightd to me, try the dumper device first
then you will see if leds are really set... also make sure the boblightd is woking if you send stuff there from vlc or somewhere else...
i suspect the "/dev/spidev0.0", namely the spi devices are not there in my build.. http://neophob.com/2012/08/raspberry-pi ... pi-device/ ?
[device]
name device1
output dd bs=1 > /dev/null 2>&1
channels 6
type popen
interval 20000
debug on
Stasik0 wrote:it seems a problem with the boblightd to me, try the dumper device first
then you will see if leds are really set... also make sure the boblightd is woking if you send stuff there from vlc or somewhere else...Code: Select all
[device] name device1 output dd bs=1 > /dev/null 2>&1 channels 6 type popen interval 20000 debug on
well after running boblightd there is a spidev0.0
pi@raspberrypi ~ $ ls /dev/spidev0.0
/dev/spidev0.0
but without running boblight, there isnt.
question:
this is for kernel 3.1 (3.2.2) your image has 3.6.11
i dont know if i apply the patch from that page what happens since the kernel is newer.
maybe i just need to do this after an update/upgrade:
5) Remove SPI from the Blacklist
$ cat /etc/modprobe.d/raspi-blacklist.conf
# blacklist spi and i2c by default (many users don’t need them)
#blacklist spi-bcm2708
blacklist i2c-bcm2708
i dunno, maybe this? http://www.raspberrypi.org/phpBB3/viewt ... 66&t=11617 maybe https://github.com/Hexxeh/rpi-update ? maybe update/upgrade? maybe /dev/spi is created with root by python and can not be overwritten by the system?
Stasik0 wrote:i dunno, maybe this? http://www.raspberrypi.org/phpBB3/viewt ... 66&t=11617 maybe https://github.com/Hexxeh/rpi-update ? maybe update/upgrade? maybe /dev/spi is created with root by python and can not be overwritten by the system?
thx to rpi-update and un-blacklisting spi, now boblighd works, now im trying your stuf:)
btw boblight might support ws2801 http://code.google.com/p/boblight/wiki/ ... spberry_Pi natively, you might need to do an svn update in the boblight-read-only folder and recompile it if you wanna play
IT WORKSStasik0 wrote:
but
there's a little delay (it is about 1 sec but it is annoying
leds color (lights) are late to the video
and the colors arent in the right order.
and the video plays very slow, like a stop motion movie
the cpu load is too high... try to reduce the number of leds in the config, you can reorder them in the config aswell.... try to use -p to bypass audio encoding....
still for my case i have boblightd already running on my wireless router
, you may also try to play with the parameters --boblight-margin and --boblight-sizedown
Stasik0 wrote:the cpu load is too high... try to reduce the number of leds in the config, you can reorder them in the config aswell.... try to use -p to bypass audio encoding....
still for my case i have boblightd already running on my wireless router, you may also try to play with the parameters --boblight-margin and --boblight-sizedown
running video like this:
./omxplayer -p --boblight-host localhost -b ~/big_buck_bunny_720p_surround.avi
and my boblight.conf is: http://pastebin.com/wUsDsLsC
(can you help me how to install boblight to my dd-wrt enabled router? is it a good idea since my leds are connected to the pi itself?)
just set boblight for 25 lights and see if it is better there is a boblight.conf_25 in the /home/pi dir
well I ended up installing latest trunk openwrt which has (since yesterday) a fixed boblightd package... note that you will need an arduino or smth for controlling lights (like me)... I ended up using these arduino sketches http://www.ambilight4pc.com/adalight.html
Stasik0 wrote:just set boblight for 25 lights and see if it is better there is a boblight.conf_25 in the /home/pi dir
Well, playing videos with this omxplayer (without the leds and boblightd)
Is very bad, chopy slow.
It is very strange that it is slow, coz with raspbmc (xbmc) i can play video on the pi and watch it on the tv via composit, and in the very same time i can run the same video on my macmini (from the pi's hdd via samba) in xbmc and send the boblight-addon data from osx to the pi-s boblightd to run my leds, and the video keeps playing at normal speed.
Omxplayer doesnt use the gpu?
it does, did you check the gpu memory split in the config.txt? try recompile by running make clean and make.... try to observe top output for cpu and memory ratings.... maybe it is because of your 512 version? maybe you need to adjust some compile flags like architecture?
here i can play 1080p without problems as you can see on the youtube video...
Stasik0 wrote:it does, did you check the gpu memory split in the config.txt? try recompile by running make clean and make.... try to observe top output for cpu and memory ratings.... maybe it is because of your 512 version? maybe you need to adjust some compile flags like architecture?
Maybe it is slow here coz i drive the leds from the pi, not with other hardware like your setup: pi+arduino.
For now i guess i wait until someone came up with some solution and i watch movies like before (osx->boblightd on the pi->leds)
Thx for the help and the effort!
Ps: i keep your img on the server for others who want to give it a try. (If its ok with you if not you can delete it)
try to remove the following section from OMXVideo.cpp (2 times)
and recompile
OMX_PARAM_U32TYPE singlestep_param;
OMX_INIT_STRUCTURE(singlestep_param);
singlestep_param.nPortIndex = m_omx_split.GetOutputPort();
singlestep_param.nU32 = 1;
omx_err = m_omx_split.SetParameter(OMX_IndexConfigSingleStep, &singlestep_param);
if(omx_err != OMX_ErrorNone)
CLog::Log(LOGERROR, "%s::%s - error OMX_IndexConfigSingleStep omx_err(0x%08x)\n", CLASSNAME, __func__, omx_err);
i think i did it
modified that file (commented out those lines two times with // ) and run make:
result, still chopy video playback and the lights are out of sync with 1 sec late.
cpu usage during video playback is:
pi@raspberrypi /usr/local/src/omxplayer $ make
/usr//bin/g++ -std=c++0x -pipe -mfloat-abi=hard -mcpu=arm1176jzf-s -fomit-frame-pointer -mabi=aapcs-linux -mtune=arm1176jzf-s -mfpu=vfp -Wno-psabi -mno-apcs-stack-check -O3 -mstructure-size-boundary=32 -mno-sched-prolog -march=armv6zk -DSTANDALONE -D__STDC_CONSTANT_MACROS -D__STDC_LIMIT_MACROS -DTARGET_POSIX -D_LINUX -fPIC -DPIC -D_REENTRANT -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_CMAKE_CONFIG -D__VIDEOCORE4__ -U_FORTIFY_SOURCE -Wall -DHAVE_OMXLIB -DUSE_EXTERNAL_FFMPEG -DHAVE_LIBAVCODEC_AVCODEC_H -DHAVE_LIBAVUTIL_OPT_H -DHAVE_LIBAVUTIL_MEM_H -DHAVE_LIBAVUTIL_AVUTIL_H -DHAVE_LIBAVFORMAT_AVFORMAT_H -DHAVE_LIBAVFILTER_AVFILTER_H -DOMX -DOMX_SKIP64BIT -ftree-vectorize -pipe -DUSE_EXTERNAL_OMX -DTARGET_RASPBERRY_PI -DUSE_EXTERNAL_LIBBCM_HOST -Wno-psabi -I/opt/vc/include/ -I/usr/local/src/omxplayer/firmware/opt/vc/include/interface/vcos/pthreads -I/usr/local/src/omxplayer/firmware/opt/vc/include -I/usr/local/src/omxplayer/firmware/opt/vc/include/interface/vmcs_host -I/usr/local/src/omxplayer/ffmpeg -I/usr/include -I/usr/include/freetype2 -I./ -Ilinux -Iffmpeg -c OMXVideo.cpp -o OMXVideo.o -Wno-deprecated-declarations
OMXVideo.cpp: In member function âvoid COMXVideo::WaitCompletion()â:
OMXVideo.cpp:1329:19: warning: unused variable âstarttimeâ [-Wunused-variable]
OMXVideo.cpp:1329:30: warning: unused variable âendtimeâ [-Wunused-variable]
/usr//bin/g++ -L/usr/local/src/omxplayer/firmware/opt/vc/lib -L/usr/local/src/omxplayer/ffpmeg -L/lib -L/usr/lib -lfreetype -lboblight -L./ -lc -lWFC -lGLESv2 -lEGL -lbcm_host -lopenmaxil -Lffmpeg_compiled/usr/local/lib/ -o omxplayer.bin linux/XMemUtils.o utils/log.o DynamicDll.o utils/PCMRemap.o utils/RegExp.o OMXSubtitleTagSami.o OMXOverlayCodecText.o BitstreamConverter.o linux/RBP.o OMXThread.o OMXReader.o OMXStreamInfo.o OMXAudioCodecOMX.o OMXCore.o OMXVideo.o OMXAudio.o OMXClock.o File.o OMXPlayerVideo.o OMXPlayerAudio.o OMXPlayerSubtitles.o SubtitleRenderer.o Unicode.o omxplayer.o -lvchiq_arm -lvcos -lrt -lpthread -lavutil -lavcodec -lavformat -lswscale -lpcre
strip omxplayer.bin
top - 20:56:43 up 16 min, 3 users, load average: 0.85, 0.70, 0.55
Tasks: 80 total, 4 running, 76 sleeping, 0 stopped, 0 zombie
%Cpu(s): 93.9 us, 5.1 sy, 0.0 ni, 0.3 id, 0.0 wa, 0.0 hi, 0.6 si, 0.0 st
KiB Mem: 253912 total, 163236 used, 90676 free, 14080 buffers
KiB Swap: 102396 total, 0 used, 102396 free, 95664 cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
2318 pi 20 0 102m 22m 2788 R 58.0 8.9 0:15.86 omxplayer.bin
2263 root 20 0 12860 1628 1392 R 31.4 0.6 0:22.78 boblightd
2267 root 20 0 9808 4236 2488 R 7.1 1.7 0:14.21 python
2316 pi 20 0 4656 1400 1024 R 1.3 0.6 0:00.40 top
28 root 1 -19 0 0 0 S 1.0 0.0 0:00.87 VCHIQ-0
37 root 20 0 0 0 0 S 0.6 0.0 0:02.62 mmcqd/0
2301 pi 20 0 9800 1648 1008 S 0.3 0.6 0:00.12 sshd
1 root 20 0 2140 724 616 S 0.0 0.3 0:01.69 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
i may have spotted the problem in the code, let me tweak it for a couple of days
Stasik0 wrote:i may have spotted the problem in the code, let me tweak it for a couple of days
Ok thx!
ok, i have got a multithreaded version that runs much better (at least here). Testers are welcome: http://vzoltan.com/stasiko/omxplayer.bin
Stasik0 wrote:ok, i have got a multithreaded version that runs much better (at least here). Testers are welcome: http://vzoltan.com/stasiko/omxplayer.bin
THX
video is just FINE !
i have to reorder my leds coz with your boblight it doesnt follow the video's color but i have no idea what is wrong, since with my other setup (as you saw the youtube video of mine) they are organized just fine.
can you help me with that?
i have 50 leds like this (assuming you are standing infront of the tv)
12 on the left
26 on the top
12 on the right
none on the bottom
first led is in lower left corner and goes up than right then down.
it is very importent to reorder them via software, coz they are fixed on a frame behind the tv!
The reordering is made in boblightd.conf... Is your image mirrored? I may mix up x and y values..
Stasik0 wrote:The reordering is made in boblightd.conf... Is your image mirrored? I may mix up x and y values..
I really dnt know
i will test it tommorow with a standard boblight-x11 client and report
Here it is my setup just to understand my situation with my leds and its order:Stasik0 wrote:i will test it tommorow with a standard boblight-x11 client and report :)
https://www.icloud.com/photostream/hu-h ... 8gBYG2OfIA
Especially the last two pics
(But i didnt get this result with your config)
One quarter of the screen is covered by 6 leds on the sides (bottom corners)
6 on the sides and 13 on the top for the two top quarters
You can count the leds on the last pics and compare to the paused video on the screen.
Thank you.
