nadnerb
Re: Boblight possible?
Thu May 02, 2013 10:22 pm
errusty wrote:
sicvolo wrote: errusty - get the XBMC boblight addon, shutting lights with the screensaver one of the options it offers. Just make sure its boblight priority number is bigger (meaning it's less important), so it does not blank out leds when the video is playing.
Hi! I've installed the boblight addon from the repository, but immediately after activation, the lights change the color that I have put in the background. From that moment in the movies do not work leds, when before all was fine. How can you set it to keep things running as before and simply use the option to turn off the lights when screensaver?
Thank you!
The plugin conflicts with the modified OMXplayer and will cause videos to not have any LEDs.
You may be able to disable boblight plugin for movies, I can't remember, but I found it best to just avoid the plugin and use boblight-constant if you want a static colour.
sicvolo
Fri May 03, 2013 4:08 am
nadnerb wrote:The plugin conflicts with the modified OMXplayer and will cause videos to not have any LEDs.
Actually, it does not, as long as you set the priority in boboptions.txt lower than the one set in the add-on. Look at the boblightd client.cpp code - it's all there.
nadnerb wrote:You may be able to disable boblight plugin for movies, I can't remember, but I found it best to just avoid the plugin and use boblight-constant if you want a static colour.
The advantage of the plugin over boblight-constant is that the plugin is aware of the XBMC state. I, for example, don't want to have my tv backlit when I am away, so the plugin turns off the backlight when the XBMC screensaver comes up after a period of inactivity.
errusty
Fri May 03, 2013 6:11 am
Hi! Thanks for the answers!
nadnerb wrote: The plugin conflicts with the modified OMXplayer and will cause videos to not have any LEDs.
At the end, I disabled the pluggin, but maybe later I'll try what Sicvolo says about priorities.
Regarding the delay, what do you think about my results of executing TOP while I running a video? I dont know hoy to know the CPU usage.
https://dl.dropboxusercontent.com/s/zbm ... o6/top.jpg
Please, when you can, comment here how is the best way to OVERCLOCK the pi and which are the values that have you used to do it, like arm_freq, Core_freq o sdram_freq (I found this website, is correct this method? http://www.jeremymorgan.com/tutorials/r ... pberry-pi/ ), or maybe modify the file Boboptions to improve the delay????
Thank you again.
nadnerb
Fri May 03, 2013 5:02 pm
errusty wrote:Hi! Thanks for the answers!
Thank you again.
From the output of top I don't think you need to overclock as your CPU isn't being maxed out.
If you are running Raspbmc then you are already overclocked. If you want to OC further, then you can use the Raspbmc settings within XBMC.
As for what is causing the delay, I don't know. Can you post your boblight.conf
nadnerb
Fri May 03, 2013 5:29 pm
Thanks, I didn't know that. Although I do wonder if this is adding extra cycles to the CPU if its also running, I shall have to do some tests.
groove
Tue May 07, 2013 9:45 am
Speedy1985 wrote: Also i'am busy to make a mod for boblight-xbmc plugin. :)
So everybody can use this plugin on 2 weeks.
What modification are you planing? So that the modifications to omxplayer are not needed anymore or that the modifications work better together with the plugin?
davisdmg
Thu May 09, 2013 10:43 am
Hello guys! I managet to get them working! I'm using raspberry -> usb -> arduino -> leds!
Do you have any tool to configure the leds this way? 20 top, 10 sides, 5 and 5 bot?
alpini
Fri May 10, 2013 10:30 am
Hi Guys,
Pibob with 50 leds works well, just need to make it 100 leds so then i can make the frame for the leds.
Can i ask you all 2 things:
1
I want to make 100 leds ws2801 and wall-mount my plasma.
How to get my own boblight.conf with 100 leds via Winscp into my Pi ???
I can log in via Winscp into my Pi.
Witch file do i have to change or delete in de Pi?
Is it the file in: /etc Boblight.conf ???
When i want to delete the original "Boblight.conf" file it gives an error:
De opdracht 'rm -f -r "boblight.conf"'
gaf foutcode 1 terug, samen met de foutmelding
rm: cannot remove `boblight.conf': Permission denied.
2
This is how i use the Boblight configuration tool for calculating my leds.
Channels Top: 32
Channels Left: 20
Channels Right: 20
Channels Sub: 32
Boblight conf. Tool calculates channels 100 (see in the right corner) when i do this setup for the leds?)
Type: ws2801
Output: /dev/spidev0.0
Channel: 300
Prefix: 41 64 61 00 63 36
Postfix: A5
Interval: 20000
Rate: 48000
Is this good ???
Channel is 100 leds x 3(rgb)= 300
Prefix, seems to be also a calculation. 25 leds or 50 leds or 100 leds have standard Prexfix
Postfix, really dont know if its good. It was already A5
Interval and Rate is also info from another forum.
Any ideas if this wil work fine?
Thank alot again
alpini
Fri May 10, 2013 10:36 am
davisdmg wrote:Hello guys! I managet to get them working! I'm using raspberry -> usb -> arduino -> leds!
here you can download the "Boblight Configuration Tool"
http://www.sedu-board.de/sedu-ambilight ... onfigtool/
NietGiftig
Fri May 10, 2013 10:41 am
Seems the permisions for etc/boblight.conf are not correct.
Log in as root or try with sudo
alpini
Fri May 10, 2013 11:34 am
Thanks NietGiftig,
Indeed, had to make sudo passwd root,
then logged in via Winscp.
Can you give any help over Boblight conf. tool ?
Are the values correct ?
Tnx again.
davisdmg
Tue May 14, 2013 8:24 am
Hello guys, as I told you before, I did it with an arduino + raspberry + 50leds.
I have done a tutorial (in spanish). If someone want to read it, it is here:
http://www.grabthiscode.com/diy/como-mo ... l-intento/
If you dont understand anything, I have no problem in translate it for you.
Mikka
Tue May 14, 2013 9:37 am
Hi all,
i have a qustion about use raspberry pi and boblight.
Is SPI support required? If so how can i test (see spi support enabled) it?
Thx
Speedy1985
Tue May 14, 2013 7:48 pm
Hi Folks!
I have updated my git repo.
https://github.com/Speedy1985/boblightd-for-raspberry
I have changed some code in the libboblight.so "sendrgb function" .
This function is realy slow on 50 or more leds so i have replaced the ToString converting to the Boost library.
Now it have better cpu usage.
To compile use this howto.
https://github.com/Speedy1985/boblightd ... to-compile
Kidn regards Speedy1985
Paypal Donation: [email protected]
Github: http://github.com/speedy1985
Facebook: https://www.facebook.com/boblightenigma2
Twitter: http://twitter.com/boblightenigma2
Support: webchat.freenode.net #boblight-enigma2
NiklasO
Tue May 14, 2013 9:07 pm
Speedy1985 wrote:Hi Folks!
Hi Speedy1985!
I used your code instead of the one suggested here:
https://dl.dropboxusercontent.com/u/688 ... tware.html
I changed all the names of the lights in the conf-file to numbers 001-050 but I don't know if I understand your instructions correctly. This is the original file: http://dl.dropbox.com/u/6885567/boblight_50xWS2801.conf
What do i need to change?
I tried to change to 001 to 050 for name on all the lights but i get nothing when playing a movie.
My lights worked when I used the original repo from the Pibob-page.
Thanks!
Wiese66
Wed May 15, 2013 8:53 am
I did a checkout and compile yesterday and wondered why configure failed (libtool) and later boost was required but not checked before. Now everything is clear :)
And yes, this version is absolut great. I currently use 96 LEDs and the difference between image and light is now minimal and great for me :)
So thanks a lot!
Chris
NiklasO
Wed May 15, 2013 8:58 am
So thanks a lot!
Chris
Could you please share your boblight.conf?
Thanks!
Wiese66
Wed May 15, 2013 9:49 am
NiklasO wrote: Could you please share your boblight.conf?
Thanks!
Yes. I´m happy to do so. But not until today evening (GMT+1).
Greetings
Chris
NiklasO
Wed May 15, 2013 9:56 am
Thanks!
Greetings
Chris
Great. Thanks!
I use this conf now but I don't know how to change it to make the lights work with Speedy1985's version:
Maybe you can point me in the right direction?
Niklas
Sweden
Edit:
Ok, so I changed all the names to 001, 002, 003, 004 up to my 050 but the leds does not work. I get a fast white flash from all the leds every time I stop playback. I used the source from the how-to first that worked. Do I have to clean it out somehow before compiling and installing this modified version?
Wiese66
Wed May 15, 2013 12:17 pm
NiklasO wrote: Ok, so I changed all the names to 001, 002, 003, 004 up to my 050 but the leds does not work. I get a fast white flash from all the leds every time I stop playback. I used the source from the how-to first that worked. Do I have to clean it out somehow before compiling and installing this modified version?
Just a guess:
Have you "killed" the running boblightd before you "make install". Maybe the binary is still the old one and the lib is new?
Just try:
top
to get the PID of the running boblightd. Then
sudo kill [PID]
and do a fresh
sudo make install
Maybe you get some information when you then start your boblightd manually:
sudo boblightd -f /etc/boblight.conf
Best luck
Chris
davisdmg
Wed May 15, 2013 12:18 pm
This is my boblight.conf
https://www.dropbox.com/s/xy423w6kj76ldwq/boblight.conf
It is working with speedy compilation and the pos of the leds are:
NOT clockwise:
--------20------.
10 .............. 10
.---5---------5---
Hope this helps to you guys. Remember, my leds are NOT clockwise
NiklasO
Wed May 15, 2013 3:33 pm
Thanks for your help!
I found my problem. I changed 00 to xx for all the lights (I know 00 should work).
When doing that I found a garbage character in one of the names.
Removed that and now it works!
h264 running with boblight. Looking good!
Wiese66
Wed May 15, 2013 7:08 pm
NiklasO wrote: I found my problem. I changed 00 to xx for all the lights (I know 00 should work).
Great, congratulations! So no need for my file anymore.
Have a lot of fun :)
skyblaster
Thu May 16, 2013 3:24 pm
Followed the PiBob tutorial substituting boblightd with Speedy1985's modified version. I'm now able to stream full bitrate Blu-ray backups over NFS without buffering. Everything is MUCH peppier now. A big thank you to all involved!
Speedy1985
Thu May 16, 2013 3:33 pm
skyblaster wrote:Followed the PiBob tutorial substituting boblightd with Speedy1985's modified version. I'm now able to stream full bitrate Blu-ray backups over NFS without buffering. Everything is MUCH peppier now. A big thank you to all involved!
Nice to hear that!!
