Re: Boblight possible?
Hi Guys,
How to get Speedy configuration into my Pi ???
I saw his "How to compile" guide.
I have installed Pibob a while ago and everyting works fine, accept the colors could be better offcourse:-)
Do i have to delete the file of Naderb or does it automaticly overwrite it ?
Will it to clash with the file of Naderb.........
Thanks alot
Thanks alot
Anyone.....
Come on guys....
I did go to:
To compile use this howto.
https://github.com/Speedy1985/boblightd ... to-compile
Did in ssh:
sudo apt-get install make gcc g++ git libboost-dev libtool
DONE
Then did:
cd ~
Did get in prompt:
pi@raspbmc:~$
Then i did:
git clone git://github.com/Speedy1985/boblightd-for-raspberry.git
Did get:
pi@raspbmc:~$ git clone git://github.com/Speedy1985/boblightd-for-raspberry.git
-bash: git: command not found
Beats me, i grow up with Windows guys
Please help
What do i have to do?
Pibob is working in Pi, boblight is nice .
Want to have Speedys configuration, sounds better they say !?
Come on guys....
I did go to:
Did in ssh:
DONE
Then did:
cd ~
Did get in prompt:
pi@raspbmc:~$
Then i did:
Did get:
Please help
You did not start withalpini wrote:Anyone.....
I did go to:
Did in ssh:
DONE
sudo initctl stop xbmc
sudo apt-get update
See https://dl.dropboxusercontent.com/u/688 ... tware.html
Part 2.1
did:
sudo apt-get update
But still no luck after doing: cd ~
Please give me step by step the lines that i have to do in ssh
Realy dont know how to fix this problem.
did:
sudo apt-get update
cd ~
Did it bring you to your home dir?
any user can return immediately to its home directory by typing the following and then pressing the Enter key:
cd ~
This is easier than typing the full name of the user's home directory, for instance, /home/josephine in the case of a user named josephine. (And it is just one of the numerous shortcuts that help make the command line on Unix-like operating systems so easy to use.)
cd ~
alpini wrote:Hi,
did:
sudo apt-get update
sudo apt-get install git
Hi I have some problems with boblight, maybe you can help me.
I ordered http://www.ebay.co.uk/itm/230873716903? ... 1497.l2649 this and as it says 0.02A in every led I calculated 1A for total. So I'm using 5V 1.2A power. I connected cables as it was instructed in https://dl.dropboxusercontent.com/u/688 ... tware.html, White - DAT - pin 19, Green - CLK - pin 23, Blue - GND - pin 6. And power to power cables. Other end of led strip is untouched. I have fresh raspbmc card and I compiled Speedys stuff as instructed in https://github.com/Speedy1985/boblightd ... to-compile. No problems there I suppose. Boblightd runs as expected but when I try to run boblight-constant 00ff00 nothing happens. Any ideas how to solve? I'm willing to try anything
My conf file is as follows. Maybe problem is in my conf file. At one point I got 3-4 light on from the other end, but not anymore. Can it make any difference that I'm running this on first revision raspberry with only 265Mb memory.
[global]
interface 127.0.0.1
port 19333
[device]
name ambilight
type ws2801
output /dev/spidev0.0
rate 115200
channels 150
interval 10000
prefix 41 64 61 00 31 64
delayafteropen 1000000
[color]
name red
rgb FF0000
gamma 1.0
adjust 1.0
blacklevel 0.0
[color]
name green
rgb 00FF00
gamma 1.0
adjust 1.0
blacklevel 0.0
[color]
name blue
rgb 0000FF
gamma 1.0
adjust 1.0
blacklevel 0.0
[light]
name xx1
color red ambilight 1
color green ambilight 2
color blue ambilight 3
hscan 50 60
vscan 88 100
and so on
- Speedy1985
Is this problem also when you play a movie ?Rusakko wrote:Hi I have some problems with boblight, maybe you can help me.
[global] interface 127.0.0.1 port 19333 [device] name ambilight type ws2801 output /dev/spidev0.0 rate 115200 channels 150 interval 10000 prefix 41 64 61 00 31 64 delayafteropen 1000000 [color] name red rgb FF0000 gamma 1.0 adjust 1.0 blacklevel 0.0 [color] name green rgb 00FF00 gamma 1.0 adjust 1.0 blacklevel 0.0 [color] name blue rgb 0000FF gamma 1.0 adjust 1.0 blacklevel 0.0 [light] name xx1 color red ambilight 1 color green ambilight 2 color blue ambilight 3 hscan 50 60 vscan 88 100 and so on
and is boblightd started ?
gr speedy1985
Paypal Donation: boblightenigma2@gmail.com
Github: http://github.com/speedy1985
Facebook: https://www.facebook.com/boblightenigma2
Twitter: http://twitter.com/boblightenigma2
Support: webchat.freenode.net #boblight-enigma2
I haven't tried the movie yet, just constant light as i tought it would be nice to get lights working first. Should i try movie too? Is my conf file ok
try with my config file:Rusakko wrote:I haven't tried the movie yet, just constant light as i tought it would be nice to get lights working first. Should i try movie too? Is my conf file ok
https://www.dropbox.com/s/xy423w6kj76ldwq/boblight.conf
Remember to change type to ws2801
and output to spidev0.0
- Speedy1985
Hi, i am now busy to mod the orginal xbmc-addon to PiBob
But on this moment there is a error in the code.
I will fix this error soon.
See code and howto install :
https://github.com/Speedy1985/boblight- ... -raspberry
https://github.com/Speedy1985/boblight- ... berry/wiki
Kind regards Speedy1985
Did not work. I tried to flash raspbmc again and compiled again as described.davisdmg wrote:try with my config file:Rusakko wrote:I haven't tried the movie yet, just constant light as i tought it would be nice to get lights working first. Should i try movie too? Is my conf file ok
First led lights when I connect power. But I can not control even the color of that one led. If I tap the cables, led changes the color and flickers but does not stay in any color but light blue, nearly white.
Is there any difference which end of the cables I connect to raspberry? And only one end should be connected, right?
boblightd is running and displays setup succeeded when I start it. And boblight-constant says connection opened when I run it, and that is the last line and then it stays there until I stop it by pressing ctrl+c.
Any ideas, is there a way to light all led with out raspberry, should they light when power is connected.
actually it's the last led that lights, not the firstRusakko wrote:Did not work. I tried to flash raspbmc again and compiled again as described.davisdmg wrote:try with my config file:Rusakko wrote:I haven't tried the movie yet, just constant light as i tought it would be nice to get lights working first. Should i try movie too? Is my conf file ok
Yes there is a difference each cable has an data in and a data out side (SDI and SCL).Is there any difference which end of the cables I connect to raspberry? And only one end should be connected, right?
The + and ground are on both sides the same.
Witch side and witch colors you have to find via your reseller or if that is not possible, Google is your friend
http://lmgtfy.com/?q=ws2801+color+code+stripe
NietGiftig wrote:Yes there is a difference each cable has an data in and a data out side (SDI and SCL).Is there any difference which end of the cables I connect to raspberry? And only one end should be connected, right?
Apparently I did not read that too carefully and missed the input sideConnector wires: White- DAT, Green-CLK, Blue- GND
Naked wires: Red- power supply "+"5V , Blue- power supply "-"(GND) 5V
Input: female side(IC side)
So I have to try another end tomorrow, I think I chose the wrong side
Hi Speedy1985, any update on this?Speedy1985 wrote:Hi, i am now busy to mod the orginal xbmc-addon to PiBob
Now now the lights are on. I had the wrong end of cables. Thank you all. Next video and moded xbmcRusakko wrote:NietGiftig wrote:Yes there is a difference each cable has an data in and a data out side (SDI and SCL).Is there any difference which end of the cables I connect to raspberry? And only one end should be connected, right?
http://lmgtfy.com/?q=ws2801+color+code+stripeApparently I did not read that too carefully and missed the input sideConnector wires: White- DAT, Green-CLK, Blue- GND
And the video works fine. Great.Rusakko wrote:Now now the lights are on. I had the wrong end of cables. Thank you all. Next video and moded xbmcRusakko wrote:NietGiftig wrote:
Any idea is it possible to get leds working with stand alone bluray player. I mean getting hdmi or some other signal in to the raspberry and using the leds while passing the signal out from hdmi to amplifier. Something like that, grab display signal and use i to control leds while other, more powerful player plays the actual video from bluray
hello, i've been trying to follow these guides and i'm stuck.
i have a raspberry pi and 4 strings of 25 ws2801's. i first tried nadnerb's guide https://dl.dropboxusercontent.com/u/688 ... tware.html and it all seems to go fine except nothing happens. i'm fairly certain i've got the wiring correct as it matches http://learn.adafruit.com/system/assets ... 1344878827 and these are mine http://www.insomnia.org/led/documentati ... s2801.html. i've got the clock, data and ground wires attached to the pi and the 5v and ground attached to a 5v adaptor. When i say nothing happens, i can start the boblight daemon and send the "turn all to green" command and the pi reports success through SSH but no lights come on. Actually i see similar to what russako reported with regard to only the last led coming on when i move the string around and this lead me to investigate whether i had the led's wired back to front. i think initially i did have them the wrong way round, i assumed a female connector indicated the input on the led's but closer inspection of the led shows IN and OUT printed on either side of the led plus the controller chip is on the side marked IN. I now think the male connector is the input end of the leds. however even trying the other way around resulted in nothing. i'm using the boblight.conf that nadnerb provides plus 2 of my led strings
i then tried speedy's new build which also doesn't work. it compiles fine and i can start the boblight daemon but when i try to send the command to turn all to green i see repeated messages of which the most useful indicator is something that says SO_ERROR and "broken pipe". i can't find much else around the web that helps me further than this. i'm using the boblight.conf downloaded from nadnerb's dropbox again as it seems like this should work and placed it in the etc folder
I've tried both builds twice and switched the wiring of the lights around in between so i think i've tried all options in terms of physical config. unfortunately i'm a linux noob, although possessing reasonable common sense when it comes to computing, so my investigations on the software side are limited to information i can source from elsewhere.
i would really appreciate any help or direction anyone can provide?
thanks!
thanks!
hello again, so i fixed 2 mistakes. i read speedy's final instruction again and then realised that my lights aren't the ones i linked to so they were connected wrong. i am pretty certain they are correct now but when i send the constant command just the first light comes on. it turns off when i control+c but no other lights come on. feels like i'm close but i can't see what else is wrong, anyone any pointers?
thanks
thanks
Hi
I've managed to get boblight working on my raspberry pi with video/movies, even youtube videos via the youtube addon. However I have a slight issue that when streaming live tv from tvheadend i get no lights. Also found that if i try to change channel XBMC restarts. Just to give a bit more detail of what i have setup, I've followed the following instructions for my setup.
I have 100xWS2801 LEDS
http://pibob.nadnerb.co.uk/software.html#part1
but used the source for boblight from here - https://code.google.com/p/boblight/wiki ... spberry_Pi
Also used https://www.dropbox.com/s/uyw6u829cb9ut ... 514.tar.gz this copy for the omxplayer.
So as i said all works just not working from a tvheadend tv stream and also the crashing of xbmc.
I've got this log capture which you can see i can watch a recorded TV video fine (springwatch), then I start watching live tv channel (BBC1) i then change channel to BBC2 and thats when XBMC reboots.
I know an odd one but i'm thinking its something to do with the OMXplayer as first port of call ?
Thank you for any help on this one.
spencapl
19:18:02 T:2762994752 NOTICE: AddOnLog: Tvheadend HTSP Client: CHTSPConnection - SendGreeting - connection opened to 'HTS Tvheadend 3.3.525~g8e08c9d~precise', protocol v10 (timeshift enabled)
19:18:02 T:2744161344 NOTICE: Thread PVR GUI info updater start, auto delete: false
19:19:13 T:2864604224 NOTICE: Thread Jobworker start, auto delete: true
19:19:13 T:2843604032 NOTICE: Thread PVR Channel Window start, auto delete: false
19:19:14 T:2776495168 NOTICE: Thread Background Loader start, auto delete: false
19:19:16 T:3037687808 NOTICE: COMXPlayer: Opening: pvr://recordings///Springwatch 2013, TV (BBC TWO), 20130530_190000.pvr
19:19:16 T:3037687808 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
19:19:16 T:2776495168 NOTICE: Thread COMXPlayer start, auto delete: false
19:19:16 T:2776495168 NOTICE: Creating InputStream
19:19:16 T:2776495168 NOTICE: Creating Demuxer
19:19:17 T:2776495168 NOTICE: Opening video stream: 0 source: 256
19:19:17 T:2776495168 ERROR: Zeile x = enabled=true
19:19:17 T:2776495168 ERROR: Zeile x = host=localhost
19:19:17 T:2776495168 ERROR: Gefundener Host = localhost
19:19:17 T:2776495168 ERROR: Zeile x = port=19333
19:19:17 T:2776495168 ERROR: Zeile x = priority=128
19:19:17 T:2776495168 ERROR: Zeile x = sizedown=112
19:19:17 T:2776495168 ERROR: Zeile x = margin=5
19:19:17 T:2776495168 ERROR: Zeile x = timeout=35
19:19:17 T:2776495168 ERROR: Zeile x = interpolation=0
19:19:17 T:2776495168 ERROR: Zeile x = speed=100
19:19:17 T:2776495168 ERROR: Zeile x = autospeed=0
19:19:17 T:2776495168 ERROR: Zeile x = saturation=1.0
19:19:17 T:2776495168 ERROR: Zeile x = threshold=15
19:19:17 T:2776495168 ERROR: Verbinde zu Host = localhost auf Port: 19333
19:19:17 T:2776495168 NOTICE: OMXClock using video as reference
19:19:17 T:2776495168 NOTICE: Creating video thread
19:19:17 T:2705269824 NOTICE: Thread COMXPlayerVideo start, auto delete: false
19:19:17 T:2776495168 NOTICE: Opening audio stream: 1 source: 256
19:19:17 T:2776495168 NOTICE: Creating audio thread
19:19:17 T:2696881216 NOTICE: Thread COMXPlayerAudio start, auto delete: false
19:19:17 T:2776495168 NOTICE: Opening Subtitle stream: 2 source: 256
19:19:17 T:2705269824 ERROR: Output - renderer not started
19:19:17 T:2696881216 NOTICE: OMXClock using audio as reference
19:19:17 T:2705269824 ERROR: Previous line repeats 6 times.
19:19:17 T:2705269824 NOTICE: Display resolution DESKTOP : 1920x1080 @ 50.00 - Full Screen (16)
19:19:17 T:3037687808 NOTICE: Using GL_TEXTURE_2D
19:19:17 T:3037687808 NOTICE: GL: Using BYPASS render method
19:19:17 T:3037687808 NOTICE: GL: NPOT texture support detected
19:19:19 T:2705269824 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
19:19:20 T:2705269824 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
19:19:28 T:2705269824 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
19:19:36 T:2776495168 NOTICE: COMXPlayer::OnExit()
19:19:36 T:2776495168 NOTICE: OMXPlayer: closing audio stream
19:19:36 T:2776495168 NOTICE: Closing audio stream
19:19:36 T:2696881216 NOTICE: thread end: OMXPlayerAudio::OnExit()
19:19:36 T:2776495168 NOTICE: OMXClock using video as reference
19:19:36 T:2776495168 NOTICE: OMXPlayer: closing video stream
19:19:36 T:2776495168 NOTICE: Closing video stream
19:19:36 T:2705269824 NOTICE: thread end: video_thread
19:19:36 T:2776495168 NOTICE: OMXPlayer: closing subtitle stream
19:19:36 T:2776495168 NOTICE: Closing subtitle stream
19:19:36 T:2776495168 NOTICE: COMXPlayer::OnExit() deleting demuxer
19:19:36 T:2776495168 NOTICE: COMXPlayer::OnExit() deleting input stream
19:19:37 T:2776495168 NOTICE: Thread Background Loader start, auto delete: false
19:19:38 T:3037687808 NOTICE: OMXClock using video as reference
19:19:43 T:2776495168 NOTICE: Previous line repeats 1 times.
19:19:43 T:2776495168 NOTICE: Thread Background Loader start, auto delete: false
19:19:46 T:3037687808 NOTICE: COMXPlayer: Opening: pvr://channels/tv/All TV channels/0.pvr
19:19:46 T:3037687808 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
19:19:46 T:2776495168 NOTICE: Thread COMXPlayer start, auto delete: false
19:19:46 T:2776495168 NOTICE: Creating InputStream
19:19:46 T:2776495168 NOTICE: Creating Demuxer
19:19:46 T:2776495168 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
19:19:46 T:2776495168 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
19:19:47 T:2776495168 NOTICE: Opening video stream: 0 source: 256
19:19:47 T:2776495168 ERROR: Zeile x = enabled=true
19:19:47 T:2776495168 ERROR: Zeile x = host=localhost
19:19:47 T:2776495168 ERROR: Gefundener Host = localhost
19:19:47 T:2776495168 ERROR: Zeile x = port=19333
19:19:47 T:2776495168 ERROR: Zeile x = priority=128
19:19:47 T:2776495168 ERROR: Zeile x = sizedown=112
19:19:47 T:2776495168 ERROR: Zeile x = margin=5
19:19:47 T:2776495168 ERROR: Zeile x = timeout=35
19:19:47 T:2776495168 ERROR: Zeile x = interpolation=0
19:19:47 T:2776495168 ERROR: Zeile x = speed=100
19:19:47 T:2776495168 ERROR: Zeile x = autospeed=0
19:19:47 T:2776495168 ERROR: Zeile x = saturation=1.0
19:19:47 T:2776495168 ERROR: Zeile x = threshold=15
19:19:47 T:2776495168 ERROR: Verbinde zu Host = localhost auf Port: 19333
19:19:47 T:2776495168 NOTICE: OMXClock using video as reference
19:19:47 T:2776495168 NOTICE: Creating video thread
19:19:47 T:2696881216 NOTICE: Thread COMXPlayerVideo start, auto delete: false
19:19:47 T:2776495168 NOTICE: Opening audio stream: 1 source: 256
19:19:47 T:2776495168 NOTICE: Creating audio thread
19:19:47 T:2680157248 NOTICE: Thread COMXPlayerAudio start, auto delete: false
19:19:47 T:2776495168 NOTICE: Opening Subtitle stream: 3 source: 256
19:19:47 T:2696881216 ERROR: Output - renderer not started
19:19:48 T:2776495168 NOTICE: Opening audio stream: 1 source: 256
19:19:48 T:2680157248 NOTICE: OMXClock using audio as reference
19:19:48 T:2696881216 ERROR: Output - renderer not started
19:19:48 T:2696881216 ERROR: Previous line repeats 7 times.
19:19:48 T:2696881216 NOTICE: Display resolution DESKTOP : 1920x1080 @ 50.00 - Full Screen (16)
19:19:48 T:3037687808 NOTICE: Using GL_TEXTURE_2D
19:19:48 T:3037687808 NOTICE: GL: Using BYPASS render method
19:19:48 T:3037687808 NOTICE: GL: NPOT texture support detected
19:20:02 T:2776495168 NOTICE: FlushBuffers: q:0 pts:-4503599627370496 a:1
19:20:02 T:2696881216 NOTICE: OMXClock using audio as reference
19:20:02 T:2776495168 NOTICE: Previous line repeats 1 times.
19:20:02 T:2776495168 NOTICE: PVRManager - PerformChannelSwitch - switched to channel 'BBC TWO'
19:20:02 T:2776495168 NOTICE: Creating Demuxer
19:20:02 T:2776495168 NOTICE: Closing video stream
19:20:02 T:2776495168 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
19:20:02 T:2696881216 ERROR: OMXPlayerVideo: Got MSGQ_IS_ERROR(-1) Aborting
19:20:02 T:2696881216 NOTICE: thread end: video_thread
19:20:03 T:2776495168 NOTICE: OMXClock using audio as reference
19:20:03 T:2776495168 NOTICE: Closing audio stream
19:20:03 T:2776495168 NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
19:20:03 T:2680157248 NOTICE: thread end: OMXPlayerAudio::OnExit()
spencapl
After lots of research I did not find solution to my problem with flickering LEDs.
Here is my setup:
ubuntu(13.04)->xbmc(12.2)->boblight addon
raspberry->boblightd->SPI->leds(100x ws2801)
boblight on ubuntu was compiled with :
boblight on raspberry was compiled with :
xbmc boblight addon conf :
boblight conf :
I tried several configurations but leds are still flickering.
Even with boblight-constant or VZoltan's php
Is that someone could help me?
Here is my setup:
./configure --without-portaudio --without-opengl --without-x11 --prefix=/usr
./configure --without-portaudio --without-opengl --without-x11 --without-libusb
speed = 50
autospeed = 25
interpolation on
saturation = 1.10
value = 1.50
threshold = 20
[global]
interface 0.0.0.0
port 19333
[device]
name ambilight
#output python /home/pi/popen.py
channels 300
#type popen
type ws2801
interval 120000
#prefix 5A B0
#postfix A5
rate 48000
debug off
[color]
name red
rgb FF0000
gamma 1.0
adjust 1.0
blacklevel 0.0
[color]
name green
rgb 00FF00
gamma 1.0
adjust 1.0
blacklevel 0.0
[color]
name blue
rgb 0000FF
gamma 1.0
adjust 1.0
blacklevel 0.0
[light]
name 1
hscan 46.88 50
vscan 95 100
[light]
name 2
color red ambilight 4
color green ambilight 5
color blue ambilight 6
hscan 43.75 46.88
vscan 95 100
Can you post A video of your flickering?
Check that you have a good common ground for the LEDs and the pi.
The data and clock wire are very sensible to interference check that they have a good connection and are isolated properly...
In some bad quality LEDs there are soldering residue that cause flickering on some LEDs I had this on 1 out of my 100 LEDs.
Well...
You were right.
I checked (move up side down) every wires at rear of each led, when arrived to 97th the last 2 led were shutdown.
Then it was impossible to control the leds, then I lost my ssh connection.
When I plug the power the power led light up and that's all..
I took the pi out of his box to check it, the proc heats very quickly and very hard and nothing else happens...
My pi is dead
Edit :
My sd card also died...
Well... F*ck you too electronics's god !
You were right.
My pi is dead
Edit :
...unfortunately, I also have the same experience. Led strip should reverse the connection wires (+ black and - red), but the power wires correctly. I have not checked it, it was raspberry polarity and is destroyed
