The plugin conflicts with the modified OMXplayer and will cause videos to not have any LEDs.errusty wrote:Hi! I've installed the boblight addon from the repository, but immediately after activation, the lights change the color that I have put in the background. From that moment in the movies do not work leds, when before all was fine. How can you set it to keep things running as before and simply use the option to turn off the lights when screensaver?sicvolo wrote: errusty - get the XBMC boblight addon, shutting lights with the screensaver one of the options it offers. Just make sure its boblight priority number is bigger (meaning it's less important), so it does not blank out leds when the video is playing.
Thank you!
You may be able to disable boblight plugin for movies, I can't remember, but I found it best to just avoid the plugin and use boblight-constant if you want a static colour.
